Best place to get borax in US? Cheaper than dept. store?
Jun 23, 2013
5
Hi, I've finally re-opened my pool after leaving it covered for a couple of years. Has a lovely green tint to it :cry: plus some disappointing numbers:
FC 0
pH 6-6.2
TA 60
CYA 30
I forgot that pH needs to be increased first, so I shocked it yesterday which unfortunately did nothing.
After some reading I've found that the pH needs to come up first and foremost, and alkalinity a little bit. I was looking to get 12-15 boxes of 20 Mule Team Borax to put in there, but the stuff seems way more expensive than it used to be (could've sworn I got it for like $4 or $5 a box).
Does anyone know of a place that's currently a good source of borax at a good price?
I used a test strip that gives you the results for pH/FC/TA/CYA.
Throw the strips as far as you can....then, go pick them up and throw them further. repeat until they are off your property. :lol:
I doubt your pH is that low and I think you are about to overdose big time. Invest in a good kit so you can have some faith in your testing and I think you will find you need far less borax.
