Thread: Best place to get borax in US? Cheaper than dept. store?
    Hi, I've finally re-opened my pool after leaving it covered for a couple of years. Has a lovely green tint to it plus some disappointing numbers:
    FC 0
    pH 6-6.2
    TA 60
    CYA 30
    I forgot that pH needs to be increased first, so I shocked it yesterday which unfortunately did nothing.
    After some reading I've found that the pH needs to come up first and foremost, and alkalinity a little bit. I was looking to get 12-15 boxes of 20 Mule Team Borax to put in there, but the stuff seems way more expensive than it used to be (could've sworn I got it for like $4 or $5 a box).
    Does anyone know of a place that's currently a good source of borax at a good price?
    26k gal, IG vinyl, 1 HP Pentair WhisperFlo Pump, Pentair FNS Plus 36 DE Filter, Pentair 460732 MasterTemp 250 NG Heater, King Tec Pool Frog XL Pro Chlorinator/Mineral Purifier, Pentair Kreepy Krauly Prowler 820 robotic cleaner
    30,419
    Re: Best place to get borax in US? Cheaper than dept. store?
    Welcome to the forum. What size is your pool? How did you get a test result of 6.0 - 6.2 for pH?
    I found 6 boxes at Kmart yesterday for $1.50 per box.
    I asked if they had more and they said that was all they
    had in stock. It's well worth looking for if you have a
    store in your area.
    20k, vinyl, inground
    Sand Filter, 1.5 hp pump
    Taylor 2006 test kit
    Down South in the Magnolia State
    Thanks! It's a 30' round, about 22000 gallons. I used a test strip that gives you the results for pH/FC/TA/CYA.
    I found some boxes at Rural King for $4 a piece, that's the best I've found so far. I'll check the Kmart and see what they've got, thanks.
    30,419
    Throw the strips as far as you can....then, go pick them up and throw them further. repeat until they are off your property.
    I doubt your pH is that low and I think you are about to overdose big time. Invest in a good kit so you can have some faith in your testing and I think you will find you need far less borax.
