Thread: Help! IG vinyl liner separating from top
    NJ
    14
    As the owner of a new home with an inground vinyl pool, I am in a bit of a panic because about 15" of the the liner is separating from the top. Is this a problem that my husband and I can fix ourselves, or do we have to call someone? Are we going to have to drain the pool?
    I shouldn't let anyone in the pool until it's fixed, right?
    Thanks!
    ETA: OK, I just found the post below RE: this issue.
    ~30K IG vinyl w/Hayward DE filter; inline chlorinator; Hayward gas heater; Polaris 280
    Welcome!
    Good luck, and feel free to ask any other questions you have along the way!
    8200 gallon 20' x 48" round vinyl frame pool, manually chlorinated with 10% liquid, salt added to ~2000, 12" sand filter, 1600gph pump, TF100 test kit
    Mod Squad JohnT's Avatar
    SW Indiana
    9,199
    You should be able to get it back in the track. Might involve some grunting and cussing. If it won't go, pour some hot water from a faucet over the liner below the gap to make it easier to stretch. If it keeps coming out, you can get a product called liner lock to hold it in, or just wedge a penny or popsicle stick behind it.
    yup, an easy fix just as John said - some hot water and you're in business, just don't use BOILING water.
    In this case, it may even stretch back into place with only a little elbow grease since it's a relatively mild case.
    Liner lock is always a good thing to have on hand for these issues.
    Kinguni's Avatar
    Winnipeg, Canada
    144
    Looks like that will be a piece of cake compared to the spot I need to do. I have to wait for the weather to warm up though. Pool is under 60°F still.
    NJ
    14
    YAY...I fixed it! The sun finally got over to shine directly on that part of the liner, and I was able to pop it back on.
    Now, where's the "hands clapping" smiley?! edit
