Thread: Adding CYA and Borax
    mellenw
    Guest
    Do I need to add cyanuric acid before borax or not at all? I drained and repainted epoxy. in-ground 15K pool sand filter, tab chlorinator in line. North TX pool pool is partially shaded by huge oak tree
    30,432
    Re: Adding CYA and Borax
    Without test results, we cannot tell if you need borax to raise your pH. You will certainly need CYA regardless.
    UN1017's Avatar
    May 2012
    Sacramento, CA
    288
    Borax has two functions. 1. Like duraleigh said, borax is used to adjust levels but we have see if your levels require it. 2. It looks like you chose to do optional borates back in 2011.
    The optional borates is just that, optional. You can do it again if you want but it's not required.
    On a side note, since you are using a tab feeder then you are adding CYA whether you want to or not. Eventually it will build up to an undesirable level.
    15'x30' IG - Roman-style - 14K - Pebble Fina Classico
    Filter: Jandy CL460 Pump: Jandy Stealth SHPF1.5 SWG: Jandy AquaPure 1400 Cleaner: Jandy RayVac Test Kit: TF-100 w/SpeedStir
    Chlorine/CYA Chart----Extended Test Kit Directions----SLAM
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,067
    I'd get that pool balanced and give it a couple weeks to get to know the chemistry before adding boartes. It will mean one less variable to worry about.
    Sort of like having a honeymoon before you add kids to the mix.
