Thread: In ground pool under construction and concerned
    My 20x40 roman-end, steel wall pool is currently under construction. My concern is that my pool is not being installed with the proper size PVC plumbing and appropriate equipment.
    My pool will have the following features:
    1) 10 ft. wide entry with 2 jets.
    2) 2 cozy coves; each with 6 jets.
    3) 3 wide mouth skimmers
    4) 3 returns
    5) 4 arcing fountains
    He is using 1.5 inch plumbing, a 2 hp Hayward 2 speed pump and is also adding a 2 hp Hayward pump to run the cozy coves. Is the 1.5 inch plumbing adequate? What will happen if he uses the 1.5 in plumbing instead of the 2 inch plumbing?
    He claims that the wide mouth skimmers used only accept 1.5 inch plumbing and even if he used 2 inch plumbing, it would need to be scaled down at the point of the skimmers. Is that true?
    He is installing a Hayward DE 48 filter. I think this is undersized. If what I think is true, what size filter should he use given the two 2 hp pumps. What will happen if he sticks with the de48?
    Other than that, I believe the other equipment (salt water generator, heat pump) is appropriate.
    I've never had a pool and am really concerned, so any advice or input would be greatly appreciated.
    I just want a trouble free pool that runs efficiently. Thanks in advance.
    30,403
    Re: In ground pool under construction and concerned
    Welcome to the forum.
    1.5 will work, 2" is somewhat better. Ask PB how much to upgrade? Shouldn't be too much.
    bmoreswim's Avatar
    Jul 2012
    Central MD
    3,798
    We have a 2HP 2 speed Hayward Tristar pump. The front of the owners manual states:
    Required: 2" plumbing minimum
    Recommended: 2 1/2" plumbing or larger
    Interestingly, the manual is for all sizes of Tristar pumps. I think they are clearly emphasizing the efficiency of larger plumbing. We have 2" per my specs based on info found here. You could find the owners manual online and show him what it says. He'll either say fine and do it or cop an attitude and that could be a sign of how other issues will also be handled. There will be other issues during construction.
    On this topic I only know what the manual says and what smart people here say. I have no horse in the race. Incidentally I don't have the need for a 2HP pump but that's what came to be. At least it's a 2 speed. I think of it as the gift that keeps on costing. Best of luck making something work that makes you feel comfortable.
    18'x38' Rectangle (3'-8 1/2' deep w/ diving board) - 27K gal. w/ gray plaster
    Hayward equipment (cartridge filter, 2-speed pump, SWCG, automation) View Our Build
    Coverstar automatic pool cover | StoneMakers concrete retaining wall and decking | Merlin SmartMesh winter safety cover
    Spring 2013 Build | Dolphin Active 20 robot cleaner | Support TFP!
    Thank you for the advice/input. Hopefully, everything will go smoothly.
