Results 1 to 10 of 10
Thread: AquaRite w/ Compu Pool T15 replacement issue
    Hello everyone! I'm new to this forum and a newbie when it comes to a pool. Have an 16 x 36 inground fiberglass pool with 20k gallons. I have a Hayward AquaRite Salt system with a Compupool T15 replacement. The system is about 6 years old. Starting having problems last week. The SWG wasn't producing Chlorine. Gave it an acid bath and now it seems to work a little. The problem is that I'm having to run the SWG at 100% to hold FC and TC. My water balance is on target, but I'm having to add Di-Chlor pucks to the skimmer to help. Anyone know what could be the issue? You can see through the SWG and notice that it is gassing the water.
    20,000 gallon 18x36 Fiberglass with toe kick and sloping walls in deep end
    Sand Filter with Hayward Super Pump
    Raypack Gas Heater
    Re: AquaRite w/ Compu Pool T15 replacement issue
    BUMP
    Raypack Gas Heater
    22,553
    Telling us that your "water balance is on target" doesn't tell us what we need to know. I highly suspect that there's nothing wrong with your swg and you are fighting an algae bloom.
    Post a full set of test results and how you got them.
    What does the water look like?
    Also using pucks is a bad idea. If you need to add anything, it should be bleach and not to the skimmer.
    I used my local pool store for testing and I also test my water using strips and drops. Pool is crystal clear.
    TC 2.6
    FC 2.6
    PH 7.2
    CYA 90
    ALK 115
    SALT 3000
    My tests are very similar
    Raypack Gas Heater
    Your TA & CYA levels are a little higher than recommended, and FC is a bit lower. FC is presumably low from the problems you have been having. High TA will tend to cause the PH to drift up, but you seem to have that under control.
    My guess is that the SWG is working just fine, but you have a low level algae problem consuming your chlorine much more quickly than normal. You can confirm this with an overnight FC loss test, though I would go straight to shocking the pool as I am fairly confident this is the problem.
    The bubbles coming from the SWG are a sign that it is working. If you want further confirmation you can measure the FC level of the water coming out of the cell, which should be higher than the FC level in the pool. To do this, open the union on the output side of the SWG just enough to let enough water for a sample to test out while the cell is known to be turned on.
    How would I go about shocking the pool? Bleach? New readings today were TC 1.7 and FC 1.7
    Raypack Gas Heater
    38,478
    You would order one of the Recommended Test Kits and then read and follow the Shocking Your Pool PROCESS as described in Pool School {Which you have read a few times already ... right?}
    mas985's Avatar
    Pleasanton, CA
    11,741
    Quote Originally Posted by gstewart24
    There have been a lot of issues reported with the Compupool replacement cells so that might be your problem.
    How long are you running the cell and what are the voltage, amp and water temp readings?
    Mark
    24/7 at 100%
    Volts 25+
    Amps 6.5+
    Water temp is 87
    Outside temp is 90-94 during the day
    Its producing chlorine, but compupool seems to think I have something in the water that's eating it up.
    Raypack Gas Heater
    mas985's Avatar
    Pleasanton, CA
    11,741
    I just wanted to make sure the cell was in the operational range and it appears to be. But at 24/7, the cell should be generating over 8 ppm per day and that is a lot of FC to get used up without having any water clarity issues.
    Mark
