Results 1 to 12 of 12
Thread: Is there an overnight FC change chart with checklist?
    Pool school has a FC test of no more than .5 FC change in 24 hours.
    I've been looking for a normal FC checklist and not finding it.
    I expect to find something like this
    Overnight FC change, evaluation, checklist of observations needed
    0-.5 excellent, no action need
    5+, danger, check for
    [ ] visible aglae
    [ ] debris
    [ ] ph, cya, alka levels
    [ ] filtration flow, need cleaning?
    [ ] increased swim load without adjustment of treatment chemicals
    [ ] ncomplete shock treatment
    etc...
    And then the inbetween
    1.0 to ##.##, very good, but watch out for.....
    ###.## to ###.## good, but these actions should be taken
    ## to ####, border line, increase Chlorine for one day and if no improvement, then take these steps...
    36K gal, gunite w/ plaster,[18W x 38L x 8 deep end] 300SF cartridge, 80-100 GPM filter, Sta-rite S7M120 and Polaris 9300 electric robot. Rooftop 6 panel Solar heater, Sacramento Valley, Climate Zone 8
    Charlie_R's Avatar
    May 2013
    Mexico, MO
    2,156
    Re: Is there an overnight FC change chart with checklist?
    How much of Pool School have you read?
    The only "chart" you really need is the CYA/FC chart.
    Since every pool is unique, what works for your pool wouldn't necessarily work for someone else, say in AZ or TX.
    The Overnight Chlorine Loss Test is:
    1) no more than 1 ppm FC loss overnight (sundown to within 2 hours of sunup).
    2) no more than .5 ppm CC
    3) clear water (you could read the lettering on a quarter on the bottom of the deep end).
    Do you have a good test kit? If not, Please follow the links in Pool School and get one. This is a purchase you will be glad you did, and your pool will thank you.
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,037
    Sorry, no flow charts here. We've discussed it, but there are too many variables.
    Realistically, you'll get to know the pool's personality after a couple weeks of testing and logging the results. You'll see increased chlorine demand long before you'll see a spike in CC or cloudy water if you're religious about testing. And then when something does look amiss, you'll be able to go back and think what has changed; pool party? toddler in swim diaper? Windstorm blew crud in the pool? Heat wave?
    If CC is climbing, FC is dropping, and the solution is usually the same
    [center:suukr13t][/center:suukr13t]
    ok, just thought I would ask. strange results: FC up .5 one day and down 3.0 next, and don't think its the drops, unless the 10ml sample is more likely to show bigger swings in the numbers. my FC jumps so I thought the lower volume test would be enough. weird was PH dropping from 7.4 to 7.0, or less. added a touch of CL today, and some city water, if same results will add some alka up, but had to work today so no time for learning new chem treatments
    Butterfly's Avatar
    South Carolina
    10,045
    Quote Originally Posted by Notri4MeBikeSwim
    What are you using to chlorinate your pool? Trichlor/Dichlor are acidic and will lower pH.
    Have you added any acid?
    "Alka up" is baking soda. We use it to raise TA. For raising pH, we use Borax.
    You're done SLAMing when:
    Interesting, maybe that's the problem. I've been using kemtek chlorate 2 from home depot/lowes. 90% other ingredients. 2 gal changed ph from 7.0 to 8.0. i thought it was just 12% bleach, but now thinking something else is in it that is messing up the water treatment
    SECTION II - HAZARDOUS INGREDIENTS
    SODIUM HYPOCHLORITE ( 7681-52-9:UN1791)......... 10%
    SODIUM HYDROXIDE (1310-73-2;UN1823)............ 0.8%
    SECTION III - PHYSICAL DATA
    pH ............................ 12
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    That is fine liquid chlorine. It is not the source of your ph drop.
    What is your TA?
    Last time I checked it was 100. I'll check again tomorrow and let you know
    Yesterday
    PH 8.0
    FC 8.5
    Today
    FC 6.0
    CC 0
    TA 120
    CH 625
    PH 8.0
    CYA -- don't know, either 35 or 50. 30 to 35 if when the black dot disappears, 50 if when the dot starts getting fuzzy.
    Beginning to suspect CYA is too low
    Charlie_R's Avatar
    May 2013
    Mexico, MO
    2,156
    30 - 35 when the dot disappears. That would be close to your level. Fine there. Expect some loss of FC during the day, even on cloudy days.
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    Don't let you ph get above 7.8. I would lower it down to 7.2 whenever you get to 7.6 this will also lower your TA which may help with your ph rise. With the high calcium you have, you are at risk for scaling if you continue to let your ph get so high.
    Is you plaster new?
