Results 1 to 10 of 10
Thread: Cloudy water
    Aug 2008
    Delaware
    45
    Cloudy water
    Things are looking up!
    FC-10
    TC-10
    CC-0
    PH-7.4
    TA-110
    CH-180
    CYA-55
    Shocked the pool 2 days ago
    Water is clear...... But slightly cloudy
    I did the over night chlorine test
    Last night FC-15, TC-15
    Today. FC-10, TC-10
    My SWG READS 20% when turned all the way up
    6 bags of salt added since opening several weeks ago
    Salt reading-6000???
    Was 2300 just 2 days ago
    Added 2 40lb bags of salt 2 days ago
    Could this salt reading be altered since shocking?
    My thoughts
    Do you think I need to change my sand again?(done last year)
    I tried adding a small amount of DE into my skimmer and it temporarily cleared the water
    Could the cell SWG need cleaning?
    Could I have algae ?
    Thank you for any help
    Susi
    30X14 IG,Vinyl,13,800 Gal
    Hayward-Pro Series Sand filter(Rated flow75GPM/284LPM)
    SWG-Aqua Comfort,Polaris360 Auto Vac
    harleysilo's Avatar
    Mar 2012
    North Georgia
    1,924
    Re: Cloudy water
    No need to change sand.
    You have something living in there because you failed the OCLT.
    Do you mean you can only turn up your SWG to 20%?!?!
    Use pool cal to estimate what all the salt you added did to your pool.
    You didn't quit reach your shock target of 24 for a salt pool with CYA of 60ish.
    18'x43' Sport Pool
    19,000 Gallons Vinyl Liner 3'-3.5'-4'
    SWCG and D.E. Filter
    Test Kits - Pool Calculator - Chlorine/CYA Chart - Pool School
    Secret Weapon for Pool Chemistry Testing
    harleysilo's Avatar
    Mar 2012
    North Georgia
    1,924
    Re: Cloudy water
    If you added 320 lbs of salt it should be more like 2731, what was salt level before addition?
    18'x43' Sport Pool
    Mod Squad woodyp's Avatar
    Apr 2010
    East Texas
    9,602
    Re: Cloudy water
    Does your SWG call for a salt level of-------------6,000? Sounds awful high to me. You're not using the SWG while shocking, are you?
    May 2013
    Bay City, Michigan
    283
    Re: Cloudy water
    Quote Originally Posted by susikay
    Shocking is not just a one and done thing, it is a process that has to be followed through with from start to finish.
    What is the finish?
    CC is 0.5 or lower;
    An overnight FC loss test shows a loss of 1.0 ppm or less;
    And the water is clear.
    12500 gallons, 24 foot round above ground
    Hayward Sand filter, Pentair OptiFlo 1HP 2-Speed pump
    Aug 2008
    Delaware
    45
    Re: Cloudy water
    Will try to respond to all questions
    SWG knob keeps turning from off to high ....but the light next to 10% then 20% as I keep turning,light up .....but as I turn all the way up it stays lit at 20%
    Salt level started at 1200, then 2300 just 2 days ago( after 4 bags of salt)
    So I added 2 more bags
    My SWG calls for a level of 3000
    Yes..... Had SWG on when I shocked( Not thinking)
    So at this point I will shut down the SWG
    and shock again
    Any other suggestions?
    Susi
    Aug 2008
    Delaware
    45
    Re: Cloudy water
    I have a vinyl liner
    So....." Following through "with shocking my pool
    How long do I wait to repeat all the testing before reshocking?
    Susi
    May 2013
    Bay City, Michigan
    283
    Re: Cloudy water
    I thought the SWG was okay to have on while shocking since it helps maintain shock levels longer, you just needed to turn it off to perform the OCLT. Either way you do need to shock, and keep it at shock levels.
    Don't need to repeat all tests, just watch chlorine and keep it at or above shock levels. How often to test depends on how fast your losing it...You only lost 5 over night so maybe check every 4 hours. Can go longer if your still at shock levels or check more often if your dropping below shock levels.
    harleysilo's Avatar
    Mar 2012
    North Georgia
    1,924
    Re: Cloudy water
    You continually test while shocking to ensure your chlorine level does not drop below you target level.... It's all in pool school....
    18'x43' Sport Pool
    Aug 2008
    Delaware
    45
    Re: Cloudy water
    Thank you for your help
    Off to get more bleach
    Is it safe to swim with the high shock levels?
    I turned the SWG off while doing the OCLT
    Susi
