Results 1 to 7 of 7
Thread: Any luck replacing Hayward 250 H heater control board resistors?
    Split from original thread CE error Hayward 250 H series pool heater, natural gas. Zea3
    Did anyone have any luck replacing resistors? I have the same R15/R45 pair of shorts that several others have reported. Not anxious to spend the $350 needed to replace them.
    35000 gal IG pebble tek
    Hayward Aqua Logic w/ T-15 SWG
    Hayward 72 ft2 DE filter
    Hayward 2.5 HP pump
    ps0303's Avatar
    Jul 2011
    FL
    3,684
    Re: Any luck replacing Hayward 250 H heater control board re
    If you can replace them, go for it. Worst case is you mess up am already damaged board. People have replaced it and they say the board works.
    Paul
    http://www.gastekservice.com A word of caution: When working with gas and electrical you might want to consider a licensed contractor. Consider the value of your life and others around you. If you would like to provide a review of the help I provided, please use the following link to leave a review. gastek - Google Search,
    The real problem seems to be humidity/water getting into the electronics. I was receiving CE errors after a rain but would clear up after the weather dried up. After a while the CE errors did not go away. I pulled both boards and brought them into the house for inspection and found there was a coating of epoxy over most of the components but not all. My resistors were chard but still had continuity so I put the boards back into the heater and it worked for a day. The Florida humidity got to it quickly and by the next day CE errors were showing up again.
    Called Hayward tech support in NC and described the problem. Told them I saw others with the same problem on internet forums. They don't seem to know what causes the problem but did send my local dealer a complete set of boards "free" even though my heater was several years old. The local dealer charged me a service call, installed the boards and checked over the unit. Net cost $130.00; Was glad to get the new circuit boards and have the unit checked out.
    The service man suggested I shield the unit from rain, I agree. Taping a sheet of plastic over the control panel and also placing wide tape over the crack between the body panels on the top of the unit should help. Another suggestion is to get a magnetic sign that will cover most of the top and the control panel. It's been a few months now with the new boards and all is okay.
    Hayward Technical Services
    One Hayward Industrial Drive
    Clemmons, NC (USA) 27012
    908-355-7995
    I have not switched them out, but I will soon. I will post once I'm done.
    I went ahead and replaced both boards for the time being and it works perfect!
    linda1's Avatar
    Mar 2010
    Western Pa.
    296
    I have the same problem and burnt boards. I have replaced two so far. I sent hayward an email and complained. Told them to google the problem and see all the people with the same problem. I asked if there was a recall on the heater. They sent email saying that the local dealer will be ordering the boards and installing them. All costs including labor will be covered. That was a week ago. I still haven't heard from the local dealer. He was to call for appointment when boards came in.
    30 ft. round Conquest agp, 19,800 gal; Pentair Easy Clean 1 hp DE EC60 filter system
    Hayward H250N gas heater; TF100 Test Kit
    2 Fafco 4x20 sunsaver solar bear solar panels
    Dolphin E 10 ~ Zoomerang slide
    Majestic 8000 Above-Ground Pool Step
    ps0303's Avatar
    Jul 2011
    FL
    3,684
    Surprising the dealer doesn't have these boards. I carry two sets of these and I'm not a dealer. I guess some people do things differently.
    Paul
    linda1's Avatar
    Mar 2010
    Western Pa.
    296
    It doesn't surprise me that the dealer doesn't have the parts. We are in a rural area and when I went to buy a pool cover, they said they would have to order it. I don't think they keep much of anything in stock. I found it easier to order things I need online.
