Thread: New pentair vs pump setup
    forya's Avatar
    Jun 2013
    SE Pa (Bucks County)
    49
    I have a new IG plaster pool that was filled 4 weeks ago. I was going to try a program of 1500 rmp from 8-noon than 2350 from noon to 3 then back to 1500 rpm from 3 to 8 then off from 8pm to 8am. How do I know if that is enough, Or too much? I also just got my tf 100 test kit, what should I test? My pool will be filled for 4 weeks on monday.
    I do not have any flow meters, and really can't install any right now(don't want to mess with my warranty). At 1500 rpm my pressure gauge reads 0 and at 2350 it reads 10psi. I can feel flow out from my returns at a minimum of 12 at 1500 psi (speed preset 2). I have a chlornitor set at 5 1/2 with 5, 3 in tabs in it (I know, I know)
    25,000 Gal, Plaster, IG, Auto CL, Waterfall, IntelFlo VS Pump, Dolphin DX6 Robot, TF 100 test kit, Merlin Safety Cover Lots of Trees!, South Eastern Pa
    mas985's Avatar
    Pleasanton, CA
    11,737
    Re: New pentair vs pump setup
    Start by reading this: pool-school/pump_run_time
    Let me know if you have any questions.
    Mark
