Thread: How long do you run your SWG for?
    Turned my Aquarite system on Thursday night. Pool was about 3ppm if I remember correctly.
    I turned it on to run 6 hours a day.
    The next afternoon (yesterday) I checked it and it was
    FC 13
    TA 13 -----EDIT: TC 13
    CYA 60
    pH 7.5
    That was a big jump for one day! I turned it down to 3 hours a day and was gone all day today. It rained pretty bad earlier today but I just checked the water and the FC was 10
    I'm going to take another look at the manual and what some of the numbers it's flashing mean. The salt was 3450ppm (3250 recommended).. Every system is probably completely different but I wasnt expecting that big of a jump after turning it on for the first time in 2 years!
    Aaron
    26' Octagon, IG Pool, ~16gal, 5-5 1/2' deep, Liner, Sand Filter, Polaris Autoclear salt system, 3/4hp Pump, Pool Blaster Max Vacuum, TF-100 Test Kit.
    GreatCanadian's Avatar
    Jul 2011
    St. John's, Newfoundland
    844
    Re: How long do you run your SWG for?
    What are you using to test?
    13'x22'x52" 8,000 gallon ProSeries Pool with Borates
    Intex 110 pound Sand Filter with Zeobrite, 2650 gph pump, 0.95 hp
    Bestway SWG
    AquaPro ECO500 50,000 BTU heat pump
    GLI Whirlwind Solar Cover Reel, TF-100 Test Kit
    Sorry I meant to say TC 13*** the TA should be about 70 (I did not retest it)
    I'm using a TF-100 test kit, i've updated my Signature for the future
    Aaron
    Jul 2011
    844
    Do you know the chlorine output of that system? Is it adjustable? I mean can you adjust the % output. My first inclination is that it's working properly. Your reading of 10 after reducing to 3 hours, down from 6 hours could be normal.
    Bestway SWG
    chiefwej's Avatar
    Jun 2011
    Tucson
    2,944
    What do you have set on the panel. AquaRite has a percentage setting. If you are running it at 100% it will put out a lot more chlorine than set at 20%. That's about where I run mine w 6 hr run time, but like you said each one is different.
    chiefwej
