Thread: Liquidator install
    Jun 2012
    Farmington wv
    92
    Liquidator install
    I got my Liquidator installed as most with an above ground pool I had to close the suction valve a bit to get the flow rate up through the Liquidator. I also added a needle valve which I dont know it it is going to work for me because now I can not max out the flow meater. it seams to be keeping my fc at 6 ppm so I am going to turn it down a bit now. What do you think of the install ok or do I need to change anything?
    13500 gal 24 foot round x 4 foot deep above ground pool. Sand filter with 1.5 hp pump. City water
    Jun 2012
    Farmington wv
    92
    Re: Liquidator install
    Also I tested the fc this morning it was 6 I just retested it now is 4 does a 2ppm loss over a 90+ day seam right?
    Mod Squad JohnT's Avatar
    SW Indiana
    9,199
    Install looks fine. 2ppm loss in a day would be okay if you weren't adding chlorine with the liquidator, so it sounds like you aren't adding fast enough.
    Installed the liquidator this weekend with few problems. We opted for the 3/8 upgrade and were not pleased with the quality of the valves so we replaced them with a different type from Home Depot. I would strongly suggest that the in line be placed on the discharge side of the pump motor vs the suction side to avoid introducing air into pump. The check valves could also be seated deeper. Day 1 and I came home to a chlorine reading of 2. Working on getting as Trouble Free as possible.
    Jun 2012
    Farmington wv
    92
    Quote Originally Posted by Tgirl
    How would it work on the discharge side of the pump?
