Results 1 to 14 of 14
Thread: How many bottles of bleach?
    Jun 2012
    Howell, NJ
    977
    So a few weeks ago, I got my first truck. It's a 2002 Dodge Ram 1500 with a 4.7L V8. Quad cab, long bed. 4x4. It's amazing how hard it was to find a truck that had everything I wanted. So the question is: How many bottles of bleach can fit in the truck? Bed and cab included.
    John
    7 year old ~13,500 gal 24' AGP with 1.5 hp Proline pump, 150 sqft Pleatco cartridge, filled with well water with pH of about 4.5.
    Wanda the Whale pool vacuum, home made heater, Taylor K-2006
    Cloudy Pool? 1) Order test kit. 2) Follow SLAM
    New to TFPC? Read Pool School a few times, then post questions. PoolMath will help with chemical additions.
    Jun 2012
    Howell, NJ
    977
    Re: How many bottles of bleach?
    The other day I brought it into the shop to grease it up (turns out everything is sealed) and when it was up on the rack I noticed it had a busted leaf spring, and both sides were bent. So I took the springs out, and brought them to a place by me (rnhspring.com) and they replaced the broken leaf, re-arced the springs, and added a new leaf to each side. The back of my truck now sits up 3" higher than it did before. I have a close-up of the Sport badge so you can see my touch-up work. It was all faded, so I used some model paint to make it look better.
    John
    Butterfly's Avatar
    South Carolina
    10,045
    Very nice truck! Now, how many bottles of bleach can you get in there
    Wait, is this another contest?
    You're done SLAMing when:
    Jun 2012
    Howell, NJ
    977
    Don't forget I have all of this room inside, also.
    Forgot to post a picture of the engine:
    John
    Charlie_R's Avatar
    May 2013
    Mexico, MO
    2,156
    Loose bottles or cases of four?
    Jun 2012
    Howell, NJ
    977
    121 oz single bottles. That seems to be about all I can get around here.
    John
    harleysilo's Avatar
    Mar 2012
    North Georgia
    1,924
    Packed to the ceiling or single layer? Same question for bed too....
    18'x43' Sport Pool
    19,000 Gallons Vinyl Liner 3'-3.5'-4'
    SWCG and D.E. Filter
    Test Kits - Pool Calculator - Chlorine/CYA Chart - Pool School
    Secret Weapon for Pool Chemistry Testing
    Jun 2012
    Howell, NJ
    977
    Stacked as high as they can go. For the bed, up to the top of the sides.Tailgate open with one of those bed extender things. You know, one of these: http://www.amazon.com/Mopar-Dodge-Ram-B ... d+extender.
    This started as a joke, but I think this might actually be a fun little thing. I'll have to take some measurements sometime.
    John
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    18,967
    A 121 oz jug of Chlorox is roughly 8 lbs.
    Payload on that should be about 1600 lbs. But with new springs, let's push that to 2000.
    2000/8 = 250 jugs.
    You could probably stack them higher and overload the truck, but you wouldn't want to be unsafe, would you?
    Casey's Avatar
    SW PA
    10,421
    If we guess right... do we win the truck?!!!
    Jul 2007
    Hillsborough, NC
    520
    Will 250 jugs fit in that truck? Assuming a jug is 8" diameter at the base, with an 8' bed that works out to 12 bottles per row, then 6 rows across that is 72 rows. Double that so it can be stacked 2 high that is only 144 bottles. I don't think 100 bottles will fit in the cab. So I am going to guess another 40 in the cab for a total of 184.
    27' Round Might Sun AG Pool 18000 Gallon Intex Krystal Clear SWG Hayward Pump/Filter on a Timer
    techguy's Avatar
    Jul 2010
    Antelope, CA
    2,687
    I know my Dakota can hold 100-110 cases of Girl Scout Cookie packed as you described.
    -- Guy --
    Aug 2010
    Dallas, TX
    4,052
    I've had over a ton in the back of mine, but mine's a Dodge 2500 4x4 diesel. :P
    I picked up all 1300 lbs of salt in mine, couldn't even tell it was there. While I was there getting the salt, some crazy guys were trying to put a pallet of composite shingles into the back of a Ford Ranger. It didn't work.
    Nice truck, I bet you like it a lot!
    Jun 2012
    Howell, NJ
    977
    The math just got easier. I have found that Aldi has the best deal on bleach, so we are talking boxes of 4 96 oz bottles. They are approx. 12.5" x 13". Now I just need to measure the bed again. When I put the new springs in, I had them add a leaf, so I bet I could put 2000 lbs in there.
    John
