Thread: CYA VERY High
    CYA VERY High
    I estimate our CYA level at 200... using Taylor test kit recommended by TFP I tested a 50/50 mix of pool and tap water to receive a CYA level of 100.
    We are in the process of draining to lower CYA level. Question is how much volume can we remove before we have to worry about floating the pool? (24,000 gal IG plaster pool)
    Many thanks in advance for any/all advice.
    24,000 gal IG Gunite, Hayward NorthStar 2HP pump, Hayward 425 sq' cartridge filter
    Hayward Viio Turbo cleaner, Water Quality Pure Ozonator, built March 2010
    30,431
    Re: CYA VERY High
    drain 1/3 to be safe. refill then drain 1/3 again. Test again and drain a third time if necessary.
    Charlie_R's Avatar
    May 2013
    Mexico, MO
    2,156
    Re: CYA VERY High
    Depends on your water table height. Generally, 1/3 at a time is recommended here, repeated as many times as needed to bring it down to 30-50. Guessing here, but I would say a minimum of twice, checking the CYA after each one.
    Dang it Dave, you did it again!
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,051
    Re: CYA VERY High
    Welcome!
    A lot depends on where you are. (Hint: pool-school/read_before_you_post) If you live in Louisiana, you might strike water digging 2 feet in your yard. Other places might have to go 100 feet to hit an aquifer.
    1/3 should be a safe bet.
