Thread: Attn: Pool expert Richard320 .. Re: Algae
    I had a horrible problem with my pool. Spent a few hundred dollars at the pool store on an array of different products that did nothing but create other problems. After 3 weeks of ****, my pool actually looked worse.
    I found this forum and Richard320 gave me some links to study.
    Im not in the clear, but after a few days my water has made a huge difference by listening to him. I will continue with the bleach until it clears up.
    Thanks Richard320, glad I found ya!
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,046
    Re: Attn: Pool expert Richard320 .. Re: Algae
    Gosh, all I did was copy-n-paste the same set of inspirational links I have used dozens of times!
    By the end of today, it is now a nice blue... A cloudy blue, but finally some results.
    Just added more chlorine.. will post my finaly results. Thanks so much for getting me on the right path. You saved me lots of money.
