Thread: Funny rookie move-select your CYA sock with care
    vanessadickson's Avatar
    Jun 2012
    Kentucky
    61
    Just had to share a funny rookie move I made today. Pool pretty much perfect, but tweaking the CYA from 60-70. I thought Id be really smart and split it up this time between two socks in front of the two returns in order to more quickly dissolve the CYA.
    Took a pair of hose and poured 1/2 in each, then left them in front of my two returns for an hour. I was shocked when one of my hose was already empty! Wow, I thought, that return must really jet out water at a much higher rate than the other. My mind was racing with plumbing scenarios that made the physics of that work.....
    On closer inspection, of course, you guessed it, that hose had a run in it. So much for my "faster" dissolution rate and high speed jet. It was just about half in granular form on the bottom, which I now have to stir in.
    Lesson: chose your sock wisely. Also, I hear patience is a virtue
    TA 80
    Cal 230
    Chl 4
    CYA (too soon to tell it was 60)
    pH 7.4
    38,900 gal., UG, vinyl, SWG, Hayward w/T-15, 1.0HP pump, sand filter, Aquabot Turbo-T
    Mod Squad woodyp's Avatar
    Apr 2010
    East Texas
    9,643
    Re: Funny rookie move-select your CYA sock with care
    Quit cheaping out on pantyhose. I spend at least a dollar a pair on mine!
    30,431
    for Vanessa
    Possibly TMI from woodyp
    Apr 2010
    East Texas
    9,643
    (Shhhhhhhhhh....don't tell my wife!)
    Jun 2012
    Kentucky
    61
    good call, woody. thanks dave.
    next time, Im trying tights (thicker).
    ....or maybe Granny's support hose (even thicker). But then I might have to deal with tricky fungal issues.....
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    At all the above:
    Essential Links:
