Thread: pump capacitor
    pump capacitor
    Can I temporarily use a 3/4 hp pump start capacitor in a 1 hp pump? that is until I can get a new one Monday.
    14,500 gal pool
    Inground
    Intellichlor Salt Generator
    Water Fall
    Mod Squad JohnT's Avatar
    SW Indiana
    9,199
    Re: pump capacitor
    The actual capacitance and voltage rating determine whether you can use it, not the motor size. The value will be in mfd or ?F.
    Re: pump capacitor
    Quote Originally Posted by JohnT
    The capacitor I want to "borrow" is a 25 from my whisperflo fountain pump and the one I want to replace on the whisperflo filter pump is a 30.
    14,500 gal pool
    Inground
    Water Fall
    Mar 2012
    Tampa Bay, Florida
    166
    Re: pump capacitor
    IRRC if a substitute is required you are supposed to only go up one size. It may or may not work. The risk is you could burn out the motor starter winding (which means a new motor).
    John (DIYer). Concrete, approximately 13,000 gallon in-ground pool with adjoining concrete spa. Approximately 40 years old. Hayward Super II pump for pool and legacy Anthony Sta-Rite bronze pump CF6 for spa, VA-26 filter,(2 sets), Rheem propane heater for spa. HASA Liquidator for pool.
