Thread: Salt Water Test Trips vs Automatic Read Out
    May 2013
    Central Texas
    42
    We just started the SWG yesterday and I was going through weekly tests:
    Strips (From TFP): 1300 ppm
    Hayward Readout: 2900 ppm
    I tend to believe the readout, but why are the strips so far off?
    Rest of Results below (prior to any adjustments):
    6/22/2013 8:30
    PH 8
    FC 8.5
    CC 0
    TC 8.5
    TA 90
    CH 80
    CYA 60
    SW 2900
    Notes: SWG Installed 6/21/13
    Add 32 oz. Muriatic acid
    Add 40 lbs. Salt
    Added 24 oz. of Stabilizer
    +/-16k gallon IG pebblesheen pool with SWG, spa and waterfall, Hayward 2HP 2-speed Tri-star, Hayward 1.5HP Tri-star, Hayward 5030 Cartridge filter, Hayward H400 Heater, Sharkvac Robotic Cleaner
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Re: Salt Water Test Trips vs Automatic Read Out
    Assuming your strips are fresh and I'm guessing they are, I would trust them first. What was your salt before you added the 40lb?
    Essential Links:
    It is more likely that the SWG is correct, though it could go either way. The only common situations where the SWG are wrong (scaling and cell wearing out) all result in lower than actual readings.
    The test strips are usually quite good, but for some people they are way wildly wrong. They are also very sensitive to being exposed to moisture before being used.
    May 2013
    Central Texas
    42
    The strips are just opened (received 2 weeks ago) and the SWG is brand new.
    I went with the SWG reading and added salt. Based upon the "taste test", it would appear the SWG was closer to being accurate.
    I will retest with the strips tomorrow and compare again.
    May 2013
    Central Texas
    42
    Quote Originally Posted by TAMC93
    Todays results -
    Strips - 1,900
    Auto Reader - 3,500
    and still "tastes like salt"....
    Also - since I was circulating on a low flow setting the SWG spike the FC to 13.5. Guess it is working and I am reducing the percentage. Good to note in the future...
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Good for you. Whatever the reason, those are some lousy strips I guess.
    Essential Links:
