Results 1 to 7 of 7
Thread: new owner needs help
    Bought a Circupool Si25, installed it yesterday. Three days ago I put in 350 lbs of salt, yesterday I added 300 lbs. more. Salt test strips says I have 1630 ppm of salt in 21,000 gal pool. On the front of the control box it says I have 800 ppm of salt. When I go through the diagnostic display panel "Cell current (typically 2.5-7.8 amps when chlorine is being generated, otherwise 16-25" Mine reads 0.
    Were going to be in the 90's this weekend I'm afraid I will end up with an algae bloom.
    Sep 2009
    Greentown, IN
    914
    Re: new owner needs help
    I can't help you with your swg as I don't know that model.
    In the meantime, if you're concerned about an algae bloom, I would bump up the FC level with chlorine until I got the swg working properly.
    Indiana, ABG 24'x52" Galveston by Blue Cascade (Craigslist buy w/part of deck included), 13,500 gallons, Intex SWG, solar panels mix 2, TF-100 test kit.
    Test kits compared
    Purchase test kits
    harleysilo's Avatar
    Mar 2012
    North Georgia
    1,924
    You are going to need some bleach, until you solve your SWG issues. You should get some and raise your chlorine level to your target. I only use mine to maintain a chlorine level, never for shocking, never for start of season, this is to help preserve it.
    18'x43' Sport Pool
    19,000 Gallons Vinyl Liner 3'-3.5'-4'
    SWCG and D.E. Filter
    Test Kits - Pool Calculator - Chlorine/CYA Chart - Pool School
    Secret Weapon for Pool Chemistry Testing
    Quote Originally Posted by harleysilo
    We have a lot of powdered shock left. Should I turn the SWG off and just use the shock for now?
    harleysilo's Avatar
    Mar 2012
    North Georgia
    1,924
    I can't answer that without knowing all of your test results. You may not need anymore of whatever other chemicals the shock is adding besides the chlorine. Liquid chlorine aka bleach would be best cause it only adds the chlorine you need. You may have room in you numbers to use the shock, I just don't know without test results.
    What is your SWG's required salt level?
    18'x43' Sport Pool
    Why is my salt content so low? 1600 after adding 650 lbs
    harleysilo's Avatar
    Mar 2012
    North Georgia
    1,924
    I don't know but pool cal puts you well over 3400 ppm.
    Exactly what type of salt are you using? Where did you buy new SWG?
    18'x43' Sport Pool
