Thread: How can i check my combined bromine in a spa
    i have the taylor test kit. when doing the OTO test. i get a dark yellow reading suggesting 10 or higher.
    Can one use the regular 10cc chlorine test on bromine or am i wasting my time. i have tested it this way a couple of times to see how much combined bromine/organic matter i have.
    i seem to always get a reading of 2.5-3 even after i shock it. i am beginning to think that this test does not work with bromine.
    how can i check my combined bromine in a spa, or do i not need to do this just shock on a weekly basis?
    thanks
    topher's Avatar
    Jun 2012
    toronto, Ontario, Canada
    136
    Re: How can i check my combined bromine in a spa
    taylor has a bromine test kit.. not sure the model number though.
    13500 gallon AG, build late 90's, Hayward S220T sand filter,1Hp aqua coastal
    Gasser BBQ broilmate 155154 LP, Smoker CGK (akorn)
    Mar 2007
    San Rafael, CA USA
    12,082
    You can use any chlorine test kit to check bromine, BUT keep in mind that Combined Bromine will measure a Free Chlorine (FC). There is no distinction between Free Bromine and Combined Bromine (at least when the combined bromine is bromine combined with ammonia -- monobromamine). So bromine test kits just report this as Total Bromine and there is no need for an R-0003 reagent. Note that unlike combined chlorine, combined bromine is still a disinfectant so isn't of concern, though it can smell different than bromine.
    Bromine units are 2.25 times higher than chlorine so multiply any FC reading by 2.25 to get Total Bromine.
    Thx guys. All makes sense now
