Results 1 to 11 of 11
Thread: Help with Brown spots
    Jun 2013
    Boston, MA
    91
    Hi,
    I drained about 1/4 to 1/3 of my pool two nights ago. I promptly refilled with clean water within 15 hours after that. The stairs that were exposed to air during the draining process now have brown spots on them. If I rub my fingernails hard on the spots, they seem to come off. The spots are not easily removed; they seem like pieces of metal. What are they and how do I remove them?? I've also attached pictures of a napkin that I stuck directly into the pool and rubbed onto the spots.
    Thanks and have a great day.
    sm
    Inground pool; about 20,000 gallons (18' x 36'); pool liner (vinyl?) a few years old; Hayward pump SPX2607X10
    Jun 2013
    Boston, MA
    91
    Re: Help with Brown spots
    Pictures of napkin attached.
    Jun 2013
    Boston, MA
    91
    Correct water level?
    delete
    30,395
    Re: Correct water level?
    Even though they are different subjects, please keep your posts under one thread so responders don't get confused.
    The brown spots look like rust. Did you refill with well water?
    11,700 gal. 21' x 54" AGP, TF-100 test kit
    Jun 2013
    Boston, MA
    91
    Quote Originally Posted by K9anakin
    In my inexperienced eyes, that's what they look, and feel, like. I used water from the spigot and our house doesn't use well water. It's odd that other areas of the pool don't show the spots.
    How can I remove the spots, without damaging the liner?
    Jun 2013
    Boston, MA
    91
    Hi,
    I'm looking for more ideas on what this issue might be and how to get rid of the stains. Thanks!
    Jun 2013
    Boston, MA
    91
    Sunday bump! Please help as I only have time on the weekends to work on the pool. Thanks!
    Smykowski's Avatar
    Sep 2011
    3,065
    Do you have any pucks laying around? Hold one on the stain for a few minutes. If it disappears/fades, it's organic and proper chlorine levels will take care of it. If not, crush up some vitamin C tablets, put them in a sock or nylon, and hold that on the stain. If it disappears, it's metal/rust, and you will have to do that to all of them.
    Jun 2013
    Boston, MA
    91
    Thanks for the Vitamin C tip. I tried it on a spot and it seemed to loosen the specs to the point where I can rub it out with my finger. I called the pool company that installed the liner and they said it's likely my water has a lot of iron/metals in it. So they said to get some treatment chemicals and pour it into the pool, and that's the only way to take out the specs.
    Do you agree with this? The last thing I want to do is upset the chemistry balance of the pool. Also, my CYA levels are high already, so I don't want that getting any higher.
    Any thoughts? Thank!
    Smykowski's Avatar
    Sep 2011
    3,065
    I've never had to do it, and I've only read about it from other users, but I think for spot stains you want to use vitamin c on a spot basis like you just did. It's a lot of work, but the simplest and cheapest way to get the stains out. Wait for others to chime in, though.
