Thread: My poor lucy(pool)
    rickyislandgirl's Avatar
    Apr 2013
    Cedar Lake,IN
    58
    My poor lucy(pool)
    Hi All,
    Not a good day... Lock keys in car, getting a six pack can falls explodes on me, and the worst Liner has many many holes... How many many holes? 13 found the grandkid with the pole using it as a cane.... I could cry Lucy is only 1 year old...
    so patched the liner..... and what I found checking around the bottom is a big dip like a 1/4 deep size of a tennis ball opposite side of where all the holes were at. It could be on cove or on bottom I can't tell it's so close ....
    1. could cove collapse?
    2. could those holes washed out sand ?
    3. what can I do to fix this ?
    Thank you... and for all the expert advice.
    10,400k, AG 21 round, 1.0HP Waterway pump cartridge filter. TF-100
    Casey's Avatar
    SW PA
    10,453
    Re: My poor lucy(pool)
    I'm gasping for air about grandchild using pole as a cane!
    Water will find the lowest spot to drain so if the collapse is the lowest spot, it very well could be from the holes said grandchild has caused. The holes very well could have washed the sand out. To fix the depression, the pool must be drained and liner pulled back and/or removed.
    So sorry Lucy is having it rough!
    Apr 2013
    Cedar Lake,IN
    58
    Thanks for the info.. Loss of water overnight was an 1/8 of inch so something is leaking.
