Results 1 to 7 of 7
Thread: Lowering TA and raising PH
    A week ago my TA was a bit high at 120 & PH was 7.7. I wanted to lower TA so i added the appropriate MA & TA was then 110 & PH 7. I aerated for a week & PH raised to about 7.2 (didn't increase much). I then added MA tonight according to calculator for PH to 7.0 , but will not test TA again till morning. My issue is the TA should be lower again but it is taking such a long time to get PH to rise with this aeration. Would adding borax raise the PH up but not raise TA up much or will borax just raise TA up also?
    Lizzieann,
    27x54 AGP with Waterfall, 18,500 gallons, Waterway Sand filter- Waterway 1.5 hp -1 speed pump , TF-100 test kit, BBB method.
    38,290
    Re: Lowering TA and raising PH
    Why are you on a hurry to lower the TA?
    Not in a hurry necessarily, just trying to get to my target numbers. I want Ph where it should be for swimming purposes
    Lizzieann,
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,004
    Fire off the waterfall. That ought to drive pH up in a hurry.
    And then just maintain pH using the TA reading to help calculate the acid dose. TA will slowly come down on its own.
    Ok, so basically you are saying i don't need to worry about TA being a little high (100-120) if my PH levels are staying around 7.5. & 7.7 ?
    Lizzieann,
    Sep 2009
    Greentown, IN
    914
    When I need to lower my TA I tend to lower my ph to 7.2, still swimmable, and when it climbs up to 7.7, dose again to bring it back down until I reach desired TA. It takes some time, but it's not something that has to be done quickly. When your TA is in check, your ph won't fluctuate as much.
    Indiana, ABG 24'x52" Galveston by Blue Cascade (Craigslist buy w/part of deck included), 13,500 gallons, Intex SWG, solar panels mix 2, TF-100 test kit.
    Test kits compared
    Purchase test kits
    Richard320's Avatar
    Jan 2010
    19,004
    Quote Originally Posted by Lizzieann
    Yep.
    High TA is only a real problem if you have high CH as well, because the combination drives the Calcium Saturation Index high, which leads to scaling.
    High TA will tend to cause pH to climb rapidly. In which case you just lower it with acid. It's exactly
    the same process you're doing with the aeration, just not at a forced rate.
