Thread: Just joined and wanted to say hello
    JamesT's Avatar
    Jun 2013
    Little Rock, Arkansas
    48
    Hello, just wanted to say hi and here is my story....sorry it so long but I got started typing and just couldn't stop.
    Intex 15 x 48 purchased May 2006
    Purchased this pool from Samís Club
    Brought pool home and immediately begin the set up process on a spot that I thought was close to level. Didnít bother checking with a water level or surveyors level and I have both that I could have used.
    About half way up on the first fill up I could see this wasnít going to work. Took pool completely down and begin the back breaking task of digging out the high side. Wife and I worked on this for about 3 days straight and then reset the pool.
    Wouldnít you know it was still about a 1Ē out on the low side. Decided to just leave it and hope for the best. This will be the Eight season and itís held so far. The upright next to the drain spout did sink this year due to drain plug leaking as I was letting water out for the winter but I was able to jack that leg up and get a brick under it which did the trick and is holding.
    1st season ended in total goose pond green and was never able to correct the situation even after spending a lot of money on chemicals. Gave up around the first of August and decided to try again the next year.
    2nd season made it to about the middle of July and gave up again.
    3rd season purchased an Intex salt water generator and replaced the small 1000 gph pump with a 2500 gph pump. The new pump used 1 ĹĒ hose connectors so I had to order adapters to make everything work. The good news is it did work and this was the first time we were able to use the pool all summer long.
    4th season I removed the small hose connections and cut the holes in the side wall just enough to replace them with the 1 Ĺ hose connectors. Problem with this is I was not able to use the over the rail skimmer but with a lot of hand skimming and a good bottom vacuum ever day or so things went fairly smooth. I continued with this set up for the 5th through 7th swimming season.
    This will be the eight year for this pool and Iím wondering if it might not be time to replace it with a new one next year. But for this year I plan to plum in a through the wall skimmer thanks to the information I have gotten from this site and all the great pictures.
    8 year old Intex 16 x 48 metal frame - Intex 1600 Pump with 14" sand filter - Intex Old Style SWG (ladder broke and poked huge hole in the side)
    New 18 x 48 Ultra frame Intex - Intex 2650 pump with sand filter - Intex Old Style SWG
    doc.mosi's Avatar
    Jun 2012
    Minnesota
    52
    Re: Just joined and wanted to say hello
    Welcome to the forum.
    I have an intex that I added a through the wall skimmer to last year. I run a 3/4 hp pump with a 100 lb sand filter. Keeps it circulated well. Much better than the stock pump and filter.
    Good luck with whatever you decide.
    18ft Round Intex Metal Frame, 7000gal, 3/4HP pump, 100lb sand filter, TF-100 Test Kit, through the wall skimmer, Baqua convert...now BBB all the way. :)
    Ugly Drum Smoker (UDS), Weber One Touch gold. (I love smoky meat) :) Saving my $$ for a Big Green Egg.
    Things I use daily:
    JamesT's Avatar
    Jun 2013
    48
    Thanks for the reply. I just got a new Intex sand pump I beleive they call it a 1600 and have had it running now for a couple of days. It seems to be doing a great job.
    I'll post some pictures of my set up as I progress and as soon as I figure out how to post pictures
    JamesT's Avatar
    Jun 2013
    48
    Here is the pump i'm using now
    Casey's Avatar
    SW PA
    10,444
    Welcome to TFP! Good luck this year!
    Have you ordered a test kit? The TF-100 is pretty awesome!
    JamesT's Avatar
    Jun 2013
    48
    I have a test kit from HTH but the one you have looks like a good one....I'll be getting back to you when this one runs low
