Thread: Salt test and misc questions
    Bartlett, tn
    FC 1.5
    CC .5
    TC 2 (added bleach per pool calculator)
    Ph dropped to somewhere between 7.0 and 7.2
    TA 70 (added 1 box 20 mule team borax... Considering borate pool but as of right now 0 borates and can only handle so much at a time)
    CH 280
    CYA 45
    It only took less than a week to go from green to sparkling clear thanks to what I've read in here. Swg was installed yesterday
    I ordered the salt test (reagents not strips) when I ordered the fas/dpd test from Taylor
    Used it today after they left
    The drops looked like clumps of silver and I had to stir it with a straw in order for the solution to mix. My results were different than theirs... It looks like there are now 4000 ppm of salt in my water but my teenagers and I all question whether my new test kit is accurate or not
    Any advice on how to use this? Am I doing something wrong?
    Thx very much
    28,000 gal gunite, triton II sand filter
    Brand new pentair swg
    Re: Salt test and misc questions
    In short is the silver reagent supposed to clump?
    Thx
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    It's easy to take the endpoint too far with this test. I guess you watched the Taylor video, but I encourage to watch it again and try to follow their advice on the endpoint. Unfortunately, these tests sometimes do clump at the end but taking it too far makes it worse. Of all the tests I've ever run, the endpoint on this one is the trickiest. As a side note, Silver Nitrate will stain your hands and other things, so it's best to keep it neat and tidy as possible when handling it.
    Essential Links:
