Thread: Hayward H300 Startup Troubles
    Hi Gang,
    And the pool troubles continue...
    Tried to start my Hayward H300 heater last week, would not light. I figured it was the igniter assembly, so I ordered a new one and put it in... pulled the burners and cleaned them... cleaned the contacts on all the connectors. Still, no go. I hear it trying to fire (that clicking sound) and smell some gas after it makes the three attempts to start.. but keep getting IG on the display and no fire.
    Any ideas?
    20,000 Gallon Gunite IG Pool w/ AG attached Spa -- Built 2004
    Sta-rite S8D110 DE 106 GPM Filter
    Sta-rite Max-E Pro 3 HP Pump
    Hayward H300 Electric Pool Heater
    Polaris 380 Cleaner
    ps0303's Avatar
    Jul 2011
    FL
    3,679
    Re: Hayward H300 Startup Troubles
    So you smell gas, is this natural or propane? The igniter is clicking but no go. Then you get an IF. Even though you smell gas, put your hand on the gas valve and then turn the unit on and see if you feel the valve click. I'll say that you need a new control board.
    Paul
    http://www.gastekservice.com A word of caution: When working with gas and electrical you might want to consider a licensed contractor. Consider the value of your life and others around you. If you would like to provide a review of the help I provided, please use the following link to leave a review. gastek - Google Search,
    It's natural gas. Yep, igniter is clicking but no go. I followed the troubleshooting section of the manual last night and it says either the gas valve or control board is bad.
    I'm going to testing using a multimeter today to see if the gas valve is getting 24vac.
    Thanks!!
    Polaris 380 Cleaner
    ps0303's Avatar
    Jul 2011
    FL
    3,679
    If you put your hand on the gas valve as the unit is turned on, you should feel and hear it click. The fact that you smell gas tells me it is opening. If you heard the igniter and did NOT smell gas then I suspect the gas valve.
    Paul
