Thread: new intex 2650 sandfilter installed .... pool cloudy
    Jun 2013
    Newcastle, Oklahoma
    508
    well dang it.... had crystal clear pool, today installed sand filter pump. now, as i am new to a sandfilter, and i was trying to decode intex's lousy instructions, i accidently forgot to backwash first. so, as i fired up pump and looked in to pool, i see a tan sandy colored stream of water coming out of the return....
    after some fast cussing, i killed the pump after it spewed sandy junk in my pool for about 10 seconds, reread the instructions and found out i was supposed to backwash first
    so after backwashing til looking glass was clear, I started it on filter, water shooting through return is clean. psi on filter is about 10. my pool is not crystal clear now its not horribly cloudy, but doesnt have its sparkle and clarity that it had before i screwed it up.
    if i run this sandfilter 24 / 7 for a day or so will it clear up? or will i have to do something else?
    thanks! other than this little mishap im happy with my new intex 2650 sandfilter, it really got this pool churning.
    Partially buried Doughboy Desert Spring 16 x 32, sport pool, with 7 ft deep middle, 20,000 gallons, Hayward Powerflo Matrix 1.5 HP 2 speed pump, 250 lb sandfilter, 2 Doughboy skimmers and 2 returns. 2 cascade fountains.
    Taylor K-2006 kit. Zodiac Barracuda Ranger suction side cleaner.
    TFPC method and is crystal clear every day thanks to TFP!!!
    Mod Squad zea3's Avatar
    Jul 2009
    Houston, Texas
    9,375
    Re: new intex 2650 sandfilter installed .... pool cloudy
    You need to vacuum up the sand that spewed into the pool. Once that's taken care of it should go back to its former glory, provided you keep on top of the chemistry!
    Love TFP? Become a
    TFP Supporter!
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    18,966
    Worse things have happened. It'll settle and then you can vacuum it up.
    Apr 2012
    SW Ohio
    456
    You also needed to rinse for about a minute before turning it to filter......Mike
    18x52 intex ultra frame pool 6981 gallons, 1 HP LL pump with 19 in sand filter,BBB method,borax 50ppm
    leslies DPD test kit + fas-dpd chlorine test kit + borates test strips
    thru wall skimmer,hard plumbed with 2 returns 1 1/2 sch 40 pvc
    1 large fountain 1 inch sch 40 pvc,shut off ball valves on all
    Jun 2013
    Newcastle, Oklahoma
    508
    thanks guys. ill rinse it, turn it back on to filter and then ill vac it tomorrrow.
