Results 1 to 8 of 8
Thread: Pool just filled - need some advice
    Mar 2012
    Tampa Bay, Florida
    166
    I'm the one from the thread " Pool Remodel - Not off to a good start" (for anyone interested in the history of my project)
    Wednesday the pool company put the coating on and yesterday (Thursday) a worker did an acid clean. When he left, he started filling the pool and said to let it fill up and leave the drain (ground water) pump on until it is full. This morning the pool and spa was full, so I shut off the ground water pump and got the pool and spa pumps running right after disassembling and cleaning the DE filter really good. I replaced the DE and let the filter pumps run most of the day.
    The problem is, we received no instructions on what to do with the water. The worker said he would be back Monday. I tried to call the office for guidance but only got an answering machine. It is past their closing hours now. I am concerned about chemical imbalance, damage to the coating and possible algee starting to grow for the next 3 days. Am I being overly concerned? Can this water sit for 3 days without the chemistry adjusted with no damage? Am I just being overly concerned? The lack of communication with these guys is certainly not comforting, but I know they are very busy and can't do hand holding. If I just had some instructions to follow.....
    Any recommendations from the forum here? What would the experts do?
    John (DIYer). Concrete, approximately 13,000 gallon in-ground pool with adjoining concrete spa. Approximately 40 years old. Hayward Super II pump for pool and legacy Anthony Sta-Rite bronze pump CF6 for spa, VA-26 filter,(2 sets), Rheem propane heater for spa. HASA Liquidator for pool.
    38,470
    Re: Pool just filled - need some advice
    That is very frustrating that they would just leave you hanging for 3 days with no guidance
    I can point you to the article in Pool School: pool-school/pool_plaster_start-up
    But, who knows what the company suggests so you do not have warranty problems. I would say put some bleach in, but often adding chlorine is not recommended.
    Jul 2008
    Dallas, Tx
    128
    If you had a branded finish installed (eg PebbleTech, Diamond Brite) you could check for any manufacturer’s startup instructions online. The NPC also publishes a recommended startup guide. Have you tested the water, what are the current readings?
    20k white plaster with blue quartz, IntelliFlo VS, Quad DE 100
    1000 gal spa with natural stone waterfall
    Beach entry with 2 bubblers. Pool built Spring 2013
    Mar 2012
    Tampa Bay, Florida
    166
    I'll be testing first thing in the AM. I may add just a little Bleach and if the PH is a few tenths from the recommended end points, I'll adjust. I'll see if there is anything on the CL Industries web site for adjusting immediately after application. We are pushing water through the heat exchanger of a new heater as well, even though it is not wired up. I don't want anything to get screwed up.
    The guy is supposed to do more acid cleaning on Monday to get the splotches out (he said to expect that). I'll get pictures up soon. In general, it looks beautiful.
    Thanks guys and great board!
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    I believe you are supposed to bypass the heater if practical/possible. If not certainly do not run it. I would assume it's to avoid scale deposition in your heater. New plaster leaches calcium into the water. There are startup guidelines in Pool School.
    Essential Links:
    Mar 2012
    Tampa Bay, Florida
    166
    No valves to bypass the heater on this setup. It can't run because they haven't run the power to it yet (electric start unit).
    Terry... I could not find anything online specifically from CL Industries. They say refer to your pool builder..
    This morning I tested the PH as over 8 (off the scale) The demand test indicates I need about 1-1/2 quarts of acid. I started with 1 pint poured in slowly near the skimmer area with the pumps running. I also put the floater with 2 3" tabs in the pool. I know there is no FC yet, so I'll add a half gallon of bleach and check everything later today. Since they will be using more acid on Monday for cleaning I don't think I should get the PH down too far, but I will most likely add a couple more pints today and again tomorrow.
    Thanks.
    May 2013
    Allen, TX
    110
    You really need to talk with the company that applied the surface. They are the ones responsible for your startup unless your contract said otherwise. The more you muck with the chemicals the more outs they have if there are any problems.
    That being said, pebble pool finishes are more forgiving to start up process differences so I wouldn't worry too much. I am surprised that they left with no instructions to you.
    ~15K gal, IG gunite with new Wetedge Satin Matrix Pebble Finish installed mid 04/14, 1 HP Pentair Challanger pump, Sta-rite System 3 300 sqft cartridge filter, G3 cleaner
    Mar 2012
    Tampa Bay, Florida
    166
    Quote Originally Posted by joepaiii
    Joe Im just going to stop right now and take your advice. I'll probably leave the floater with 2 3" tablets in it because the water is pretty warm in this Florida heat. Since early this morning I have added 3 pints (total) of acid about 2 hours apart (1 pint per application at a time). I put a half of gallon of pool bleach in it and the 2 Tri-Chlor 3" tablets. The pumps are running with clean filters. I did some basic testing and the acid demand shows I need another 2-3 pints just to get it to 7.6. The FC was .6 PPM and combined was 2.8 PPM (the City water source uses Chloramines for drinking water sanitization). I've done some gentle brushing to move the cloudy water to the main drain. I think it is too early for the CYA test.
    I mentioned what you said to my wife, but she said, "so far this company hasn't taken responsibility for anything yet they did or didn't do". Anyhow... life goes on and I've got other things to do. Thanks for the comments.
