Thread: Another Iron Stain Story
    Another iron stain story.
    This year, when the pool cover was removed, I discovered six Pennsylvania field stones, that I use for garden edging, at the bottom of the pool(granddaughters confessed). Got the stones out and got everything running but I noticed the tea stains on the walls and bottom of the pool. Never having this occur in the past 20 years I thought it would go away but it didn't(evidently iron leeched out of the field stones and attached itself to the liner). I found the posts here on correcting the situation and have all the chemicals needed for the AA treatment. My questions are 1.) the Algaecide 60 recommends 2-4 ozs. weekly, is this sufficient while the chlorine is absent/low. 2.) Any guess on when the choline will be low enough to start treatment.
    FC 4.25
    CC .5
    Ph 7.4
    TH 110
    CYA 50
    Water temp 83
    Thanks
    Hayward Power Flo LX pump and Vari-Flo sand filter. 18' X 52" agp. 8000 gals. Takoma Park, MD
    BoDarville's Avatar
    Jun 2012
    DFW, Texas
    3,841
    Re: Another Iron Stain Story
    Welcome to TFP
    Quote Originally Posted by takpak65
    Yes. If those are the directions on the bottle, I would follow those. Just to be clear, make sure the "Algaecide 60" is Polyquat 60. Polyquat is the trade name and should be prominently labeled on the bottle. The active ingredient is: poly [oxyethylene (dimethyliminio) ethylene (dimethyliminio) ethylene dichloride]. Look for a 60% concentration of that ingredient.
    Every pool is different, but it shouldn't be more than a couple of days or so, especially at this time of year. Test FC to be sure. Also, don't forget to lower pH down to 7.2 before starting the AA treatment.
    BTW, just to make sure you have it, here is the full article on the Ascorbic Acid Treatment.
