Thread: How often should I backwash? Do I have a filter problem?
    Jun 2013
    New Hampshire
    20
    I'm starting to think maybe I have a problem, I am going through DE like crazy.
    So, my pool has gone from green with tons of leaves on the bottom (long story) to light blue but still cloudy in the deep end. The bottom is pretty much cleaned up as best I can tell. But now just trying to see the bottom on the deep end. It is clean in the shallow end.
    I backwash my pump (no special setting, I just open it up). It goes clear. I add DE through skimmer. I start running. The returns look great, pressure is good. However, after just 6 hours or so...my returns have virtually no pressure. I bump. I get some pressure back, but it goes away a couple hours later.
    Any thoughts? I've been letting it run with no pressure to the returns, knowing it isn't working at capacity. I have taken the top off and cleaned it with myriatic acid pre-season, which for my pump is a pain in the rear. And I got so frustrated I took it apart again and washed it out with a high pressure hose a couple weeks ago. Again, worked GREAT when I first started her up...but was disheartened when I ran into the lack of pressure to the returns a short while later. I used to think it was because my pool was so dirty, but now it really isn't bad and I'm almost there...yet I still run into the issue.
    Ben
    25,000 Gallon In-ground. DE Filter. Hayward Pump. Fairly new at this, so it's still a pain in the butt.
    Jun 2013
    New Hampshire
    20
    Re: How often should I backwash? Do I have a filter problem
    I should clarify that the pressure on my pump itself is good throughout (20 - 30). Even when there is little pressure to my returns.
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    18,967
    That sounds normal to me. All that cloudiness is getting filtered out. You ARE maintaining shock level chlorine, correct? Because otherwise, it's still growing and dying and clogging your filter. Once you get ahead of it, the filter should go longer between cleanings.
    Jun 2013
    New Hampshire
    20
    Yes, though I've had to add water to vaccuum as you have seen, so my CYA died and then my Chlorine check last night was way too low. I didn't have any conditioner at the house. I didn't want to add chlorine without any conditioner in it, as it would just burn out I would think. So I picked some up, and I'm going to add CYA and then shock the **** out of it tonight. Hoping that will take care of some of the cloudiness?
    Richard320's Avatar
    Jan 2010
    18,967
    Quote Originally Posted by Benspot
    I think the shock process would be better than a one-time mega-dose. http://www.troublefreepool.com/pool-...king_your_pool
