Thread: Maybe not worth the risk, but worth the question
    Jun 2013
    South Shore of Montreal, Quebec
    16
    Hey all,
    I have an inground pool and a spa, about 30 feet apart. The pool works wonderfully, it's on a salt system and I got nothing to say against it.
    The spa, however....... I hate it. Not the spa, the bromine chemicals and balancing ph and stuff like that.
    Now, heres my wild idea... Is there a way to slowly clean the spas water with the inground pools water? Could something nasty happen to the spas plumbing if I tried running it on salt water?
    I'd like ideas please
    cheers
    Don't have the exact gallons of my inground pool, I just know it's pretty small. A Silverado would barely fit into it I guess.
    Using a 200sqf cartridge filter, new from 06/15/2013 - broken pressure gauge
    Using vinyl and a 1hp pump
    Also using a heatpump and cleaning with salt.
    If you need more info, ask and I'll be glad to fill in and even take pictures!
    Re: Maybe not worth the risk, but worth the question
    This can be done, but it requires some fairly significant plumbing changes. You need to exchange a significant amount of water with the spa every day, which will take some effort to setup.
    harleysilo's Avatar
    Mar 2012
    North Georgia
    1,924
    Quote Originally Posted by philwire
    Hey all,
    cheers
    Man do i ever feel you on this.
    I wonder is Jason referring to plumbing changes to accommodate the water circulation between pool and spa, or plumbing changes for Spa to handle salt water?
    Biggest issue for me would be hot tub would constantly be running to heat up water, prolly run all the time. Mine would probably die from that.
    18'x43' Sport Pool
    19,000 Gallons Vinyl Liner 3'-3.5'-4'
    SWCG and D.E. Filter
    Test Kits - Pool Calculator - Chlorine/CYA Chart - Pool School
    Secret Weapon for Pool Chemistry Testing
    Jun 2013
    16
    Quote Originally Posted by harleysilo
    Hey all,
    cheers
    yeah that would also be an issue. especially in winter.
    I think I'll wait till the spa dies its slow death then I'll switch to a salt one. Then from time to time I'll dump it to the pool and pump new water from the pool to keep things well mixed up
    I think I was just hoping that spa water could be recirculated once a week or something, that would have been worth the effort IMO.
    harleysilo's Avatar
    Mar 2012
    North Georgia
    1,924
    Hey all,
    cheers
    I didn't know they made stand alone hot tubs that used SWG, so getting that when mine is dead!
    18'x43' Sport Pool
