Thread: Pump run time?
    Jul 2011
    SW France
    105
    Pump run time?
    Ok, so having put in for a new VS pump, I wanted to get some idea of how best to run this. I'm sure that there was a thread somewhere of for how best to run a VS pool pump during any given 24hrs, but cannot find it...
    my thinking is to run it as slow as possible within the perimeters of keeping the pool clean but;
    How often should the pool water be turned over in it's entirety in 24hrs? I realise that if the pool is heavily used on a sunny day then this will vary, but then I will just speed things up. I just need to find a base point.
    Do I need to run the pump on "fast" for an hour or so to clear surface muck in any given cycle?
    I realise that there is a balancing act to work out, especially with regards to the Pool Pilot, but need to start somewhere...
    thanks for any help,
    SWG - Exterior
    12x5M
    90,000 Ltrs /24,000US gallons
    Pool Pilot Digital
    Hayward Max Flo VS
    Polaris 280
    Vinyl liner
    Sand Filter
    mas985's Avatar
    Pleasanton, CA
    11,742
    Re: Pump run time?
    When in doubt, check pool school: pool-school/pump_run_time
    But in short there is no one size fits all answer.
    Mark
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,067
    Re: Pump run time?
    Every pool is different. Rule of thumb is one turnover per day. VS pumps usually have a most efficient speed, and that's what you should use unless you need more flow to run a cleaner or water features.
    Search
    mas985's Avatar
    Pleasanton, CA
    11,742
    Re: Pump run time?
    Quote Originally Posted by Richard320
    That is somewhat outdated and not really a good indicator of run time.
    Mark
    Jul 2011
    SW France
    105
    Re: Pump run time?
    Quote Originally Posted by mas985
    That's what I was looking for! Thanks.
    SWG - Exterior
    12x5M
    Pool Pilot Digital
    Hayward Max Flo VS
    Polaris 280
    Vinyl liner
    Sand Filter
