Thread: New to TFP
    wjr75's Avatar
    Jun 2013
    IL
    836
    New to TFP
    Hello All,
    First I would like to say that this site is great! Just bought a FT-100 and ran some tests listed below. I live in IL and have my pool drained/power washed and acid washed before filling every spring.
    FC-4.5
    CC=0
    TA=210
    CYA=55 ( Not sure how accurate..added 6lbs of CYA to the newly filled pool, 25k gallons)
    CH=260
    PH=7.5
    I started on lowering the TA by reducing the PH to 7.2 and then waiting for it to rise by the water aeration. I just read this article http://www.poolspanews.com/bond-financi ... watch.aspx that states to subtract 30% of the CYA value from the TA value. Is this true? I haven't seen that stated on this site since I have been reviewing the forums.
    Thanks!
    Inground 22k gallon gunite 15x31 main pool, 15x7 wading pool/sunning deck, hot tub/with overflow (9' octagon with limestone top) & slide NSWG, Aqua Blue Pebble Sheen
    Filter dual cartridge Sta-rite 450sq/ft, TF-100 Test Kit
    Heater Raypak 2100 400k btu cupro-nickel exchanger
    Auto pool cover, Polaris 280 auto pool cleaner, Jandy AqualinkRS8 Remote Control System
    Re: New to TFP
    We always use the TA value directly from the test kit and never use the adjusted TA value. The only reason to ever use the adjusted value is when calculating LSI, which has be superseded by CSI which uses TA directly, so really no reason to ever make the TA adjustment.
    wjr75's Avatar
    Jun 2013
    IL
    836
    Re: New to TFP
    Thank you for the reply. How much total muriatic acid over time do I need to add to bring my TA down from 210? Our tap water out of lake Michagan evendently has high TA.
    Thanks
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,074
    Re: New to TFP
    Quote Originally Posted by wjr75
    Thanks
    According to Effects of Adding Chemicals in http://www.poolcalculator.com/, each gallon of 31% MA will lower pH by 1.23 and TA by 20. So...maybe 7 gallons, spread out over a looooooong time. What's your target?
    I wouldn't be in too big a hurry with the TA. It's not critical for you because the CH is not really high. Just adjust pH each time it gets to 7.8, it will come down eventually. If you get tired of adjusting every other day or whatever, then commit yourself to spending a weekend with this:
    pool-school/lowering%20total%20alkalinity
