Thread: Skimmer performance with Variable Speed Pumps
    Feb 2013
    Sylvania, OH
    6
    Has anyone noticed a degrading of their skimmer's performance when using a variable speed pump and slowing it down in accordance with the manufacturers recommendations?
    Re: Skimmer performance with Variable Speed Pumps
    Sure. Skimmers need a certain minimum water flow to work correctly. Sometimes with a variable speed pump you need to experiment a little to find the minimum speed that will get the skimmer(s) to work correctly.
    mikespoolfl's Avatar
    Mar 2011
    Florida
    179
    I've found this helps some when running at low speeds. It's about 24 inches long
    Screen enclosed 17K gal 16x30 IG with Diamond Brite finish, elevated 4 jet spa with spill over, Twin dolphin fountain, Hayward Ecostar pump[ Pentair intelliflo VS, Filter Sta rite Posi-Flo PTM 100, Aqua Cal heat pump, Tiger Shark QC robotic cleaner.
    Stenner peristaltic pump model 45MPHP10, 15 gal storage tank. TF 100 with Speed Stir.
    Feb 2013
    Sylvania, OH
    6
    I'm looking at this and wondered if anyone had used it:
    www.aquapowerpool.com
