Thread: Use two liners in AG?
    May 2013
    3
    Hello,
    I recently installed an oval 15x30 above ground pool. The liner has a manufacturer defect on the seam (found out after pool was filling and noticed leak). I came across a new liner on Craigslist...still in box of same size for $50 (still can't believe the luck). My question is: Can I keep the old liner in...repair the seam tear...then install the new liner over it for added protection? What would be the possible problems? Thank you
    15x30 Oval AG. 9293 Gallon, Sand Filter, Pending install
    cramar's Avatar
    Nov 2010
    Sault Ontario
    1,143
    Re: Use two liners in AG?
    What type of liner is it (overlap, etc)?
    Can't you fix the seam?
    Can't you get it replaced under warranty?
    Personally I'd probably buy the liner as a future replacement since it's such a deal, then try to replace/repair your current liner.
    May 2013
    3
    Thanks for replying. It's an overlap. The warranty states it will only replace it...so I'd have to take it out, cut a 1'x1' section, mail it to them, then wait for them to send me a new one. I will most definitly save one or the other for future use but was just wondering if anyone has used two liners at once for the added protection against wear and tear? Especially since I have teenage boys...I need all the strength I can get
    May 2013
    3
    btw, the original liner was a 20 guage.. the new craigs list liner is 25..
    Casey's Avatar
    SW PA
    10,418
    I don't think that's a good idea. Use one liner at a time. If you try and install a liner over top of another liner, you will not get a smooth bottom or sides and it will be a big wrinkled mess.
