Page 1 of 2 12 LastLast
Results 1 to 20 of 29
Thread: The pH drifts upwards in a fairly short span of time
    Apr 2013
    San Diego
    21
    I hope you don't mind me piggybacking on this post, but I came here to post the same question.
    Post split to a new topic. Yes we mind. JasonLion
    TA = 100-110
    pH = drifts up to 7.6-7.8 within a week of me bringing it to 7.4ish
    CH = (can't recall my reading last night, but likely 200ish)
    I've found over the past month or so that the pH drifts upwards in a fairly short span of time. My TA was around 140, so I calculated how much acid to use to bring it down, then let the pH rise naturally. But now I find I've been adding acid each week to get the pH back in line. The worst thing is, I haven't really used the pool that much at all. Maybe twice in the past month!
    Any thoughts?
    Re: The pH drifts upwards in a fairly short span of time
    Lower your TA down to around 60 to 70 and see how that does.
    ComputerGuyInNOLA's Avatar
    Oct 2012
    Mandeville, Louisiana
    604
    A lot of things contribute to PH rising. Mine goes from 7.2 to 7.8 in five days like clockwork. I have two waterfalls, a sprinkler to cool the pool, a SWCG, and new plaster all of which contribute to rising PH.
    Gunite/Plaster pool at 13k gallons. All Jandy with CL340 series cartridge filter, 1.5 HP Jandy Stealth pump. Jandy 1400 SWCG and PDA4 controller. Dual waterfalls. Polaris 280. Pool installed August 2012. Southern Louisiana. And lets not forget my trusty TF100 test kit!
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    18,967
    Once a week isn't bad for adjusting pH.
    Methinks you doth protest too much.
    I adjust mine weekly - I think expecting to never have to adjust pH just isn't realistic. Mine makes about the same change over a week.
    Summer Escapes 15'x42" AGP, Intex 14" sand filter, Intex SWG
    pragmatic's Avatar
    Jul 2011
    Friendswood, TX
    521
    Same weekly regime here as well.Now that I know my pool,I just add 9oz MA every week and check only every 2 weeks. Always right on the money. Also. Keep in mind bleach has a pH of about 11.5-12. That's adds to the drift too.
    Dave My Pool Build, ODK Build
    22X42 Gunite Freeform 23K Gal, 10X12 Spa
    Diamond-Brite midnight blue, 1800sq. ft Kool Deck
    Pentair Easy-Touch 8, 2-2hp Pentair, 500lb Sand Filter, 400K btu Pentair heater
    Aug 2010
    Dallas, TX
    4,052
    Elbow, post up all your pool specifics. Do you have features (slide, fountain, waterfall), salt water chlorine generator, etc.?
    I have to adjust mine once a week, a gallon a week, and that's with borates at 50 and TA of 70.
    Mar 2011
    Houston, Texas
    413
    Quote Originally Posted by RobbieH
    I thought I had it bad. I add about a quart of MA every week with borates at 50 and TA of 70.
    9,200 gal. Gunite Luna Quartz French Grey pool with spill over spa, two fountains on tanning ledge (rarely used)
    Pentair Whisperflo 2HP, Pentair CCP Cartridge 420 Sq. Ft., Polaris 280 with booster pump
    Pentair EasyTouch 4, RayPak LoNox 266k Natural Gas heater, Aqua Rite SWCG T Cell 9, Borates, TF-100 test kit
    tcat's Avatar
    May 2012
    Austin, TX
    729
    Ditto
    Quote Originally Posted by HouTex
    IG pebble, 15,000 gallon
    48 PentAir DE Filter with backwash valve
    PentAir Whisperflo pump with 1hp 2-speed motor
    Aquabot 4WD, Poolskim
    Intermatic Dual Timeclock with freezeguard
    DIY chlorine feed
    BBB
    Aug 2010
    Dallas, TX
    4,052
    You are adjusting a 9000/15000 gallon pool. Mine is 44,000.
    Mar 2011
    Houston, Texas
    413
    Noticed that after I posted. I have it worse!!
    Aug 2010
    Dallas, TX
    4,052
    I don't have fountains or spa. That's why.
    Apr 2013
    San Diego
    21
    Here are my specifics:
    20,000 gallon pool
    No water features
    DE filter with fiberclear
    Water is new (3 months) but the plaster and pipes are old (potentially 30-40 years!)
    Pump is variable speed Pentair (new as of March)
    Chem:
    TA: 100-110
    Hardness: can't recall, but "normal" by my test strip standards. 200 ppm?
    CYA: 40-50
    Borates: ??? (Just learned about this variable and I'm wondering if checking and adjusting this might help stabilize mt pH)
    Combined Cl: 0.5 ppm
    FC (as of yesterday): 4-5ppm
    I'm using bleach for my Cl source, and have been using muriatic acid to adjust pH down weekly. Tabs occasionally.
    In light of all your responses, I'm surprised to see that having pH drifts this frequently is "normal." I assumed that with a good TA, the pH would only shift over longer periods of time and/or with heavy use. If weekly shifts of 0.4ppm is normal, than I suppose thanks to all of you for letting me in on that information.
    All the same, I'm going to check out my borates anyway, to satisfy my curiosity.
    If my pool/chem details show anything as being odd, please let me know.
    Thanks!
    Casey's Avatar
    SW PA
    10,421
    Quote Originally Posted by TheElbow
    So we have a stripper eh?
    You should really consider investing in a reliable test kit as strips can be unreliable.
    Apr 2013
    San Diego
    21
    Quote Originally Posted by Casey
    No I have the TF kit, but I didnt have the hardness reading handy and the strips were the last time I measured it (kit reading was a few weeks back)
    Casey's Avatar
    SW PA
    10,421
    Well, it's good to know you have a test kit!
    Lower your TA down to around 60 to 70 and the PH drift will slow down significantly.
    Apr 2013
    San Diego
    21
    I have no problem doing this, but isn't that a low TA? Won't it cause the pH to swing more wildly?
    Richard320's Avatar
    Jan 2010
    18,967
    It will get down there eventually if you keep adding acid to adjust pH.
  20. Back To Top    #20
    If you are using trichlor tablets as a chlorine source, then yes that is way too low a TA. But if you are using bleach, liquid chlorine, a SWG, or cal-hypo, then the recommended TA is 60 to 80 (or 70 to 90 depending) and your TA is too high, thus the PH drift.
