Thread: Manual pool vacuum operation
    Jun 2013
    Boston, MA
    91
    Hi,
    I was looking for instructions to operate a manual pool vacuum. I already have a Polaris auto-cleaner from the previous owner, but I'd like to have a back up plan. Educate me please! I'm a total pool newbie.
    Thanks
    Inground pool; about 20,000 gallons (18' x 36'); pool liner (vinyl?) a few years old; Hayward pump SPX2607X10
    Mod Squad zea3's Avatar
    Jul 2009
    Houston, Texas
    9,404
    Re: Manual pool vacuum operation
    You need a vacuum plate, vacuum hose, vacuum head for vinyl pool, and a telescoping pole.
    1. Empty the skimmer basket.
    2. Attach the vacuum head to the pole.
    3. Attach the hose to the vacuum head.
    4. Place vacuum head in water.
    5. Hold the end of the hose over the return with the pump running to force any air out of the hose.
    6. Attach the hose to the vacuum plate.
    7. Insert vacuum plate in the skimmer. Try to keep the plate under water or seal off the opening in the plate with your hand to keep as much air out of the hose as possible while putting the vacuum plate in the skimmer.
    8. Push the vacuum slowly to avoid stirring up the debris as you go.
    Check the skimmer basket if the vacuum becomes weak and empty as needed.
    Love TFP? Become a
    TFP Supporter!
    kcindc's Avatar
    Sep 2011
    Fairfax, VA
    1,275
    I have a polaris and love it, but there are times when you need to manually vacuum. I was so confused the first few times I manually vacuumed, but watching a video like the one below was really helpful to me. Make sure that you have a leaf basket in your skimmer or a leaf catcher in this video if you need to vacuum leaves and twigs.
    http://www.youtube.com/watch?v=LEu0zI9dVb4
    Karen
    33K IG w spa plaster, Pentair 1HP Whisperflo, DE Filter, SWG CircuPool RJ-60, Dolphin Triton Plus, Raypak Dig 336K BTU, TF-100.
    Pool Math Chlorine / CYA Chart SLAM - Shock Level And Maintain
    2017 replaster/retile
