Results 1 to 16 of 16
Thread: Liquid Chlorine Vs Pool Shock - Can someone answer this?
    Jun 2013
    New Hampshire
    20
    I tried to find this in a string, sorry I couldn't locate.
    I usually use the 1lb dry packets of super shock. 53% cal-hypo I think.
    How many gallons of liquid bleach = the 1lb bag powder shock?
    Thanks for your help!
    25,000 Gallon In-ground. DE Filter. Hayward Pump. Fairly new at this, so it's still a pain in the butt.
    Re: Liquid Chlorine Vs Pool Shock - Can someone answer this?
    It depends on the strength of the bleach, but roughly one gallon. (134 oz of 6% or 98 oz of 8.25% bleach)
    Also keep in mind that the LC doesn't have calcium (cal-hypo) or stabilizer (dichlor). Therefore it's better.
    Aaron
    [ Vogue Vectra 24' AG | Hard plumb: Hayward Power-Flo Matrix 1HP 2-speed, 27" sand filter & Pentair MiniMax 100 NG | Taylor K-2006 | Central IL ]
    Powered by: TFP, PoolMath & TFTestkits
    Jun 2013
    New Hampshire
    20
    When you say "LC" do you mean "Bleach" or do you mean the liquid chlorine from the pool store? I'm trying to find a cheaper alternative...
    Jun 2013
    New Hampshire
    20
    ...or are they interchangeable...
    Aug 2010
    Dallas, TX
    4,052
    If it's liquid - be it bleach or liquid shock - it won't have any CYA in it unless there's something out there I don't know about.
    If it's powder, beware.
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    18,967
    Quote Originally Posted by Benspot
    Liquid chlorine is exactly the same chemical as bleach. It is normally sold in higher concentrations, typically 10% or 12.5%, which are easier to carry than bleach. Liquid chlorine is not available in all areas. Ask your pool store if they carry it. Liquid chlorine is often less expensive than bleach, once you take it's higher strength into account. For the rest of this section I will refer to both bleach and liquid chlorine as bleach.
    http://www.troublefreepool.com/pool-...pool_chemicals
    Also see
    bleach-prices-2013-t58266.html
    comparing-chlorine-costs-t39243.html
    [center:3m9375e0][/center:3m9375e0]
    A lot of people use Clorox prices from Sam's as a basis, or Costco. If you can beat that price elsewhere, go for it. I would bet most often off-sale, it's around the best price available.
    I'm buying 10% at $12.49/4gal.
    Aaron
    Aug 2015
    Berryville/Virginia
    45
    I, too, wonder about the difference between liquid chlorine (bleach) and liquid shock (like Buckman's Liquid Shock which only lists ingredients as 12.5% sodium hypochlorite and the rest "other ingredients").
    ​aarsic
    30k gallon in-ground plaster pool, Pentair Whisper-Flo 2.0hp, Jandy AquaPure PLC 1400 Saltwater Cell, Polaris 360 w/booster pump, DE filter. Due to a brain injury I cannot do Pool Math. Don't tell me to do Pool math unless you want to walk me through the whole thing.
    38,251
    There is no reason to bump a 2 year old thread ....
    A quick search and you will see that the only difference between bleach and liquid chlorine is the strength. Bleach is anything up to 8.25% (usually 6 or 8.25). Liquid chlorine is usually 10% or 12.5%.
    Isaac-1's Avatar
    SW Louisiana
    6,711
    Jason, you can buy bleach from janitorial supply places that is commonly up to 12.5% so in other words they are exactly the same thing
    Aug 2015
    Berryville/Virginia
    45
    I think that Isaac-1 is right - through my searching at times I found they were the same, yet I would see a post or more that would say otherwise. You all give percentages - am I correct to assume the percentages you are giving are for Sodium Hypochlorite? Why not "bump" a thread if it needs more clarity??
    ​aarsic
    Mod Squad pooldv's Avatar
    DFW, TX
    24,450
    Yes, it is the percentage of sodium hypochlorite.
    The reason not to bump or hijack another poster's thread is because it is the original poster's thread and you aren't asking or answering a question for the original poster. If you want to ask your own question it is best to start a new thread.
    Mar 2007
    San Rafael, CA USA
    12,082
    Quote Originally Posted by aarsic View Post
    If you are wondering about the "other ingredients" in chlorinating liquid and bleach, see this post where you will find that it is mostly water and some sodium chloride salt. There is a small amount of excess lye (sodium hydroxide) and Clorox bleach has a tiny amount of sodium polyacrylate.
    Aug 2015
    Berryville/Virginia
    45
    Thank you Chem geek! Ah, Pooldv - I WAS asking the same question - I don't feel that it was answered adequately before and I did a search FIRST on this exact topic which led me to THIS thread. Originally the post was "liquid chlorine vs pool shock" BUT it was answered as if the question was liquid chlorine vs bleach. Not was either of us were asking. So please reread all of the questions AND answers before you jump on me. Thanks again chem geek - but I think that Isaac-1 is the only one who answered the question appropriately as it was addressed. Thank you again.
    Excellent post on the ingredients Richard.
    ​aarsic
    Jan 2014
    Buckeye AZ
    807
    It's just the way this forum is, they'd rather have 100 new threads a day on the same basic topics then everyone with a green pool posting in the same ongoing thread. Reduces cross posting and lets the op get his or her answers more easily. It does mean there are like 5 pages of new threads every day.
    Also, the original question asked how much liquid chlorine is equivalent to cal hypo. It was answered in the second post.
    10,500 gal IG, Topaz Pebble, auto-level
    Hayward DE filter, 2HP Ecostar VSP, ProLogic PS-4, GVA actuators
    Cal Pools Wave Force Plus (wall return jets plus 2 floor pop-ups), Venturi Skimmer
    Water sheer, 2 wok pots, bubbler stem on the baja step
    ColorLogic Mutlicolor LED lamp. Taylor 2006+speed stir
