Thread: Just got my test kit
    forya's Avatar
    Jun 2013
    SE Pa (Bucks County)
    49
    I have a 3 week old plaster pool and I am using the chlorinator they gave me with the 3in tabs. The water looks and feels good, so what should I be testing? All the tests? in the TS-100?
    25,000 Gal, Plaster, IG, Auto CL, Waterfall, IntelFlo VS Pump, Dolphin DX6 Robot, TF 100 test kit, Merlin Safety Cover Lots of Trees!, South Eastern Pa
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    18,970
    Re: Just got my test kit
    You can skip the CYA test for now - unless you've put in 15 lbs of pucks so far, it won't read anyway. I hope you've been keeping tabs on how many you've added so far!
    Otherwise, do them all.
    The crucial thing to keep track of with fresh plaster is the PH. You don't want to let the PH go above 8.0, and preferably not above 7.8.
    I would wait until it has been four weeks since the pool was plastered, and then test and adjust everything. You can test anything you want to right now but you don't want to adjust TA, CH, or CYA until it has been four weeks.
