Thread: Vacation, Run Filter?
    May 2013
    Ct
    77
    The pool is just about clear, still a tad cloudy. I will be going away for 6 days. Should I run the filter? I do have a timer. Ive been getting the pool clean and running the filter but the pressure goes up quick, I am worried about running it at high pressure when no one is around.
    Gunnite IG , DE FNSP36, FR90, 14000 gal.
    Sep 2010
    Orange County, CA
    52
    Re: Vacation, Run Filter?
    Is your only concern about running the filter that your pressure is getting too high? If you don't run your filter, you'll have a mess to clean up when you get back from 6 days away. It sounds like you're in the middle of cleaning up a problem?
    Southern CA 30K gal Pebble Pentair WhisperFlo 1HP 2 speed Hayward DE6020 filter Paramount Debris Canister Goldline/Hayward AquaRite Pro SWG (T-CELL 15) Sense & Dispense (acid) Pentair IntelliBrite 5G and GloBrite Inter-Fab G-Force slide Jandy deck jets Lion head spout Dolphin Premier Cleaner Taylor K-2006 test kit
    Mod Squad zea3's Avatar
    Jul 2009
    Houston, Texas
    9,410
    Do you have someone who can check on things while you are away? If not open up the filter and clean the grids out well. Put in fresh DE and bring the pool to shock level and use the timer to run the pump. If you feel uncertain about letting the pump run unattended, bring the pool to shock level, let it circulate for about an hour to mix everything in and put on the pool cover if you have one. Turn the pump off just before you leave. With luck you won't loose too much ground while you are away.
    Love TFP? Become a
    TFP Supporter!
    May 2013
    Ct
    77
    No, I dont have anyone to check the pool. I just took the cover off and Its really hard to put on, so Ill have to leave it off. It uses stakes in the ground to hold it on.
    Over the next few days I am hoping to get it nice and sparkley, then , like you said, hopefully wont come back it it icky.
    Thanks Alot
