Thread: Plano area help
    Plano area help
    I just sold my house with a pool and put a bid in on a house that does not have a pool. Problem is the house did have a pool that has been covered up. Is this going to be a major issue if I decided to put in a pool? Investment company said the pool was chipped away and filled in. My relater seems to think that it will add major cost to building a new pool. Also on that note any recommendations for a good pool builder in the plano area.
    Thanks
    Apr 2013
    Sacramento, CA
    2,769
    Re: Plano area help
    It depends.
    What does chipped away and filled in mean? Is there still a burried gunite pool shell?
    What kind of pool was it?
    Do you have good access for a full backhoe?
    I'd get bids from excavation contractors directly.
    Mod Squad pooldv's Avatar
    DFW, TX
    24,485
    Re: Plano area help
    Reber Pools builds amazing pools in DFW.
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Re: Plano area help
    Ooohhf that sounds like it could get really spendy.
    Essential Links:
