Results 1 to 14 of 14
Thread: Question Intex sand filter
    Apr 2013
    South California
    69
    In the manual stated that if the meter at yellow section, it's time to do backwash. I did but it's still at yellow when it's in operated mode.
    Question: Do we check when the sand filter is in operated mode or in off position?
    Summer Escape 4k gal-AG
    Intex sand filter 1600 GPH
    Intex SWG model 54601
    Taylor K2006 kit & Taylor Salt Water Test Kit K-1766
    Installed 4/29/13
    30,421
    Re: Question Intex sand filter
    Not sure I understand. In "off" position, your gauge should be at zero, is it?
    Apr 2013
    South California
    69
    Yes, in off as no running and the gauge is at zero. So we check when it's running?
    If that, the gauge just cross the line into yellow. I thought after do back washing, the gauge should be in green area.
    Installed 4/29/13
    Apr 2012
    SW Ohio
    456
    Ignore those instructions.....once you backwash and rinse look at the pressure gauge and note it, that is your clean pressure and once it rises 20-25% it is time to backwash......Mike
    18x52 intex ultra frame pool 6981 gallons, 1 HP LL pump with 19 in sand filter,BBB method,borax 50ppm
    leslies DPD test kit + fas-dpd chlorine test kit + borates test strips
    thru wall skimmer,hard plumbed with 2 returns 1 1/2 sch 40 pvc
    1 large fountain 1 inch sch 40 pvc,shut off ball valves on all
    Jan 2013
    Aruba
    229
    hi, can anyone tell me how often and how long i would have to backwash a intex 2650 gph on a 15x48" pool
    Intex 15X48" /5300 galloms
    Intex 2650 sand filter
    Thru wall skimmer,
    FAS-DPD chlorine test kit K-2006
    Hard plumbed
    Apr 2012
    SW Ohio
    456
    All pools are different so it is impossible to answer that question..too many factors play a role in this..but if your clean pressure is 10 you would backwash and rinse at 12.5 or 13.....how ever long it takes for that to happen is a mystery to me......like bigfoot......lol......Mike
    Apr 2012
    SW Ohio
    456
    You may have asked the un-answerable question.....Mike
    Apr 2012
    SW Ohio
    456
    As far as how long you have to backwash.....until the water in the sight glass is clear usually around 2 minutes but don't forget to rinse afterwards for about 45 seconds.....Mike
    Jan 2013
    Aruba
    229
    Thx for all the responds,i was thinking with a filter that big i wouldn't have to backwash that often.i have also seen alot of video on youtube where they tell u to back wash for 1min and rinse 30 sec.
    Ps: i would like to back wash as little as possible because our water is very very expensive
    Thru wall skimmer,
    Hard plumbed
    Hey Hpdad and to all, I bought the 16" 2650 gph intex sand filter, filled the sand a little under the max fill line and I'm getting the same thing. It started and has been just a hair under 10 psi, which is bordering the yellow mark. I've read some other sites this seems to be normal for most. Like others said this will be our "Clean PSI". I bought the big sand filter mainly because it was on a great sale so why not go a little bigger, I was ready to spend 250-300 at the local pool store so when I saw this for under 160 meh, the next one I get will be bigger so I'm thinking ahead I guess. I have the 15 X 48 intex round and there's no way I could run it for 1-2 minutes "PLUS" rinse for 1 minute, the first time I tried it drained just over 1/3 of the water. So to anyone with a smaller pool we will just have to backwash more often, it's working great. I backwash and rinse for 20-30 seconds once every 1-2 weeks depending on debris / storms I have a lot of trees around, being were all outside in the yard anyway it's not a big deal. Take care good luck have fun.
    Jan 2013
    Aruba
    229
    Thanks man,so you backwash for 30 sec and rinse for 30 sec if i'm right??
    Thru wall skimmer,
    Hard plumbed
    Matt Ush's Avatar
    May 2012
    46
    Quote Originally Posted by TCJ4
    You backwash until the site glass runs perfectly clear. Rinse for 30-45 seconds afterwards. It'll change every time you do it depending on whats caught in there. Sometimes I need at least 1:30 of backwash, sometimes only 40 seconds. Don't count the time just watch the glass.
    Inground Concrete Pool With Fiberglass Walls (20,000 Gallons), Hayward .75 Super Pump, Hayward S200 Sand Filter, Pentair IntelliChlor IC40
    Apr 2013
    South California
    69
    Another thing, there is sand in the sight class since the very first back wash. Should it be a problem?
    Installed 4/29/13
    Jun 2013
    Newcastle, Oklahoma
    508
    Quote Originally Posted by hpdad
    on my new 2650 intex sandfilter pump, it ALWAYS has sand in the sight glass after backwash UNTIL i rinse it. i just backwash until sand in SG is all i see, then rinse for 30 seconds or until glass is clear.
    mine seems to stay at 10psi after a backwash. irregardless of what the manual said (boy its confusing isnt it?! ) im just going to backwash it once a week, no matter what guage reads.
    Partially buried Doughboy Desert Spring 16 x 32, sport pool, with 7 ft deep middle, 20,000 gallons, Hayward Powerflo Matrix 1.5 HP 2 speed pump, 250 lb sandfilter, 2 Doughboy skimmers and 2 returns. 2 cascade fountains.
    Taylor K-2006 kit. Zodiac Barracuda Ranger suction side cleaner.
    TFPC method and is crystal clear every day thanks to TFP!!!
