Thread: Water level issue is spa
    Have an issue that I need help with. During the day under normal filtration my spa level is great. I have a valve that allows the water to slowly fill and overflow the spa. During the "cleaning" process the water level in the spa only drops 8 inched and when I run the spa the water stays low, thus making the jets flow about a 1/2 inch below the water line. Not ideal. Ideas on how to fix?
    18,900 Stonescapes Tahoe Blue xtra black, 8 jet Spa, Pentair inteliflo VS , Pentair FNS 60 DE, Inteliclor40, Pentair 400,000 Mastertemp heater, 3 spillovers powered by a Pentair 1 HP whisperflo pump, The pool Cleaner, 2 Intellibright color changing lights and 400 sq ft. of Heliocol roof mounted solar.
    38,303
    Re: Water level issue is spa
    What is the cleaning process? Sounds like the return line may not fully switch to the spa so it drains? Or a leaking check valve?
    We have the return side cleaner. We just amp up the speed the last hour during so it travels faster and has more suction. Im thinking the return line doesnt fully switch. If I send pics can you tell me which one is the return line?
    38,303
    Sure can try.
