Thread: Gap between coping and cement
    Wanted to know if I should be worried about a gap between the coping and the concrete apron around the pool. A lot of water ends up going between the two. Is this going to be a problem or should I put something like caulking I between the two
    16 x 38 inground pool, 20K gal, vinyl liner, 0.75 HP Hayward Superpump (SF 1.0, 115 V), Hayward Pro Serier Top Mount 24" sand filter (300lbs sand) with 62GPM design flow fate and 3.1 sq ft effective filtration area, Kreepy Krawly cleaner
    30,408
    Re: Gap between coping and cement
    Absolutely should be caulked. I like polyurethane. Strangely, PB's often do not include that as part of their responsibilities....I have no idea why.
