Thread: Testing pH
    Jul 2012
    Tulsa, OK
    24
    Testing pH
    Just got a new bottle of Taylor phenol red. 5 drops turns any water sample blood red. What is the proper number of drops to add to a Taylor comparator that came with a DPD test kit.
    I have a year old HtH kit, and 3 drops of Taylor gives a similar reading to 5 drops of HtH.
    Thanks for reading... - Tony
    Da' Pool: Intex 15'x42" 3284gal AGP EasySet (Inflatable Ring) - (Summer 2014: 27' round EW /w 6.5' deep end @ 22,500gal)
    Pump & Cart Mod: 1000gph Cart. 5ft² - 2 nylons, 24/7 OP. Traps bugs/bits, lasts longer/cleans easier = Happier Pool Owner!!
    The Bible for a "Trouble Free Pool" life = PoolSchool, the BBB method a TF100 test kit(Recommend Kits Compared). - Cleaning a Sand Filter
    Water looks like GLASS, if yours doesn't...SLAM IT! Feels nice and never been happier!!! :D
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,075
    Re: Testing pH
    Check the number on the bottle. There are two different Taylor pH test reagents.
    taylor-r-0004-versus-r-0014-t44177.html
    Jul 2012
    Tulsa, OK
    24
    Re: Testing pH
    R-0004
    Richard320's Avatar
    Jan 2010
    19,075
    Re: Testing pH
    Is your kit a TF100 or a K-2006? Or are you using Taylor reagents in an HTH kit? They're not all interchangeable.
    Jul 2012
    Tulsa, OK
    24
    Re: Testing pH
    My pH test is from a Taylor basic pool care DPD test kit. I don't see a number on the package.
    Re: Testing pH
    R-0004 is for use with the 2000 series test block, while the Residential Basic DPD kit is from the 1000 series. The 2000 series test blocks hold about three times as much water as the 1000 series, so try using one or two drops instead of 5 drops.
