Results 1 to 12 of 12
Thread: first pool opening..when to do chems?
    tookiesmom07's Avatar
    May 2013
    Tennessee
    56
    I work 11 hour days, 6 days a week. We are about to get the water to level in our pool. Should I test the water before I leave at 5 a.m. and add chemist then? I cant be home til about 6 p.m. to do anything else. And the pump should be running during all this for a few days at least right? Should I adjust chemist again if I retest when I get home? All of this is slightly confusing, especially due to our working hours. Any advice would be greatly appreciated!
    Intex Ultra-Frame 26x52 AGP (14,650 gal.)
    Intex Pump & Filter
    30,421
    Re: first pool opening..when to do chems?
    First and foremost, you must test the water. You may or may not need anything but only valid test results will tell you that. Once you have interpreted your test results (post them here for assistance) you can then determine what and how much should be added.
    May 2013
    Tennessee
    56
    Thanks! The pool is still filling. Hopefully I can test soon and post here about it.
    Intex Pump & Filter
    30,421
    Post 'em up. We'll all help you get started right.
    Jun 2013
    Sacramento, CA
    21
    I'm right there too. going to setup Pump and Filter tomorrow
    TF-100 Kit arrived yesterday. Already, dumped a gallon of liquid chlorine because I knew the water
    was going to be stagnant for a day. I'll post my results this weekend.
    18.5k Doughboy 28 round Autumn Breeze 1 HP 2 speed Hayward matrix powerflo w/ timer
    Xstream 150sq ft. Filter Cartridge, AquaBug pool cleaner. TF 100 test kit
    Jun 2013
    Sacramento, CA
    21
    Hello I don't have a chlorine reading yet to measure after dumping a gallon of 10% two days ago.
    Had a high level immediately adding so I thought I should wait a day or two first. Ph is approximately 7.5
    No CYA also.Haven't tested for TA yet. My question is do I get the FC up first then test every thing else afterwards?
    Also, how soon do I check FC after adding and how long o I run the pump? Do you check while pump runs?
    Need help please reply
    Jun 2013
    Sacramento, CA
    21
    Here's my readings after first week
    FC..5
    CC 1.0=TC 1.5
    PH 7.5
    TA 150
    CH 80
    CYA 30
    1st time checked CC a little alarmed alot of activity this week. It has been over 100 everyday
    Starting to get comfortable with test kit now
    Smykowski's Avatar
    Sep 2011
    3,065
    Your FC is too low and your CC is too high. Probably time to shock it. How does the water look?
    Jun 2013
    Sacramento, CA
    21
    Thanks for quick reply
    Added 1/2 jug 10% liquid chlorine last night
    FC up to 3 now 12 hrs later will recheck tonight for CC hopefully
    It falls. Pool still looks good running pump
    8-10 hrs a day
    Jun 2013
    Sacramento, CA
    21
    At 7:45 PST
    FC 1.5
    CC 0.5
    Nice to see CC fall to. 5, a lot kids in pool today . Temps here in Sacramento are staying well
    above 100 degrees for a week now. dropped another 1/2 gallon jug 10% tonight we'll see tomorrow
    if CC is gone. Hopefully shock treatment won't be needed.
    Jun 2013
    Sacramento, CA
    21
    6:45am
    FC. 8.0
    CC. 1.0
    TA. 170
    CH. 60
    CYA 40
    PH. 7.7
    Time to add 21oz muriactic acid
    As per pool calculator wish me luck.
    Jun 2013
    Sacramento, CA
    21
    I'm glad I waited tested again at 8:45 pm
    FC 2.0
    CC 0
    TA. 140
    CYA. 30
    PH 7.8
    I'll take for now. TA a little high and pH creeping up
