Thread: TF-100 FAS/DPD Reagent drop size same for K-2006?
    Camman's Avatar
    May 2012
    Raymond, NH
    27
    This seems like a stupid question, but, I have to ask to make sure I am not messing up my test results.
    I have a Taylor K-2006 test kit. I have been ripping through the FAS/DPD Reagent (R-0871). I exhausted the bottle that came with the kit, ordered the .75oz "Taylor Refill" size from TFTestKits and now that is also almost gone due to the large amount I've needed to use for testing during the shock process.
    Anyway, so I figured it would be a lot more economical to buy the 2oz "TF-100" refill size (http://tftestkits.net/R-0871-2-0z-Reage ... t-p53.html) for 2 bucks more than the .75oz Taylor size, but, I wanted to check and see if the "drop size" from this bottle will be the same as the "drop size" from the Taylor bottle because I am still using the Taylor comparator tube and instructions.
    See, kind of silly question, but could make a big difference if the drop sizes are different between kits. Next season I am probably going to switch to the TF-100 w/ XL because it seems like it is a lot more economical when you have to do a bunch of tests. But hopefully when I properly close my pool this season I won't need so much shock testing at the beginning of the season
    24' Above Ground, 11,800 Gallons, Hayward XStream 150sq. ft. Cartridge Filter(CC1500), Hayward Power-Flo Matrix 1.5HP Pump
    Charlie_R's Avatar
    May 2013
    Mexico, MO
    2,156
    Re: TF-100 FAS/DPD Reagent drop size same for K-2006?
    As both kits use the same sample sizes, and the same amount of R-0870, I would say yes, the drop size will be the same.
    30,432
    They are the same
    jcowart's Avatar
    Jun 2012
    Labelle, TX
    320
    Yes it is the same drop size. The 2 oz bottle has less give in it so you should not have to squeeze it. Just make sure it's straight up and down. Then let gravity do the rest.
    17500 gallon Doughboy AGP, Hayward DE filter, waiting for the 1.5hp DB pump to go out.
    Learn to take the advice here and be trouble free or use the pool store's advice. "You can't do both and get very far"
    Camman's Avatar
    May 2012
    Raymond, NH
    27
    Perfect, thanks for the quick answers everyone! The 2oz bottle seems like a much better deal than the Taylor bottle and I think my shock process is finally starting to wind down so hopefully I won't have to get anymore the FAS/DPD Reagent this season.
