Thread: CH--can it fall that fast?
    West Chester, PA
    53
    Here are my test results with my new TF-100:
    FC 5
    CC 0
    TC 5
    pH 7.3
    T/A 120
    CH 150 (we have copper that DH added, so I added the two extra R-0012 drops prior to R0011L and included them)
    CYA 40
    Temp 70
    On 5/25, the last time tested (at Leslie's Pool Supplies using a drop test) the CH was noted at 210. Is it possible for CH to drop that fast?
    Is my FC too low for my CYA?
    The pool has a solar blanket on it now until this weekend when we are ready to use it and the temp is going up to the nineties!!!
    TF-100 Test Kit, 28,000 gallon IG , 3M quartz plaster '09, 48 sq ft DE filter, Heat Siphon SX5HP heat pump '09, Polaris 360 '10, Protect-A-Child safety fence
    30,411
    Hi, Maria,
    My intial reaction to your results is that they are nearly perfect!
    How does your water look?
    Do you have a gunite or a vinyl pool?
    Ch is generally stable in pools so I would suspect a testing error on Leslie's part. Over and over, we have all learned that we test more accurately than the pool store.
    West Chester, PA
    53
    It's a gunite pool.
    The water was GREEN and sludgy but thanks to all the help here it's clear and bright, ready for summer fun.
    30,411
    For a gunite pool, CH is a little low.....200-400 is better.....I'd add a little to bring it up but maybe test it once more to confirm your first test.
    Again, the rest of your numbers are absolutely on the money....Nice work!
