Results 1 to 10 of 10
Thread: Where to go from here?
    Jun 2012
    Louisville, KY
    50
    My brand new pump I installed last year is having problems. It's run fine since installed last summer, but Tuesday evening, when I went to turn it on (manual-no timer) it just hummed for about 3 seconds then cut off. It does this every time you try to start it now.
    Did some searching and found the first thig to check was that it's not a seized motor by manually spinning the empellor and seeing if it moves. It does spin when I twist it! (Good thing, right?)
    Then I saw that its usually a bad capacitor. Got a new one today, hooked it up, and same issue. It just hums for 3 sec or so, then shuts off.
    I'm at a loss. Where do I go from here? What should I check next.
    38,000 gallon IG pool Plaster bottom & fiberglass walls
    Jandy FloPro 1.5hp, 2-speed pump
    Hayward S310T2 sand filter
    CompuPool CPSC36 SWG
    30,415
    Re: Where to go from here?
    Welcome to the forum. I am not qualified to answer that but we've got some good pump folks here who should be along shortly.
    Jun 2012
    Louisville, KY
    50
    Thanks. I'm hopin to figure something out soon. With no pump since Monday, I imagine it won't be long til I have green water.
    Jun 2012
    Louisville, KY
    50
    Nobody?
    38,272
    You have hit the usual suspects. There may be a centrifugal switch that is stuck on the end of the motor attached to a spring. See if it moves and maybe clean the contacts?
    happyheathen's Avatar
    Sacramento CA
    225
    Have there been ANY changes to the wiring in the house?
    Has any new load been placed on the circuit which feeds the pump? If there are any other items on the same circuit, do they all function as normal?
    How soon after it trips can it be re-started (such as it is)?
    Either the current is inadequate or there is some kind of protective switch being tripped.
    I'm assuming this has nothing to do with speed selection circuitry (since I have no idea what that circuitry looks like)
    Anything to make it hotter than it used to be?
    Dave
    Sacramento
    1980's 15,000 Gal IG Plaster; 1 1/2 hp Hayward Northstar; Hayward Swimclear C3025 Cartridge Filter (325 sq ft, nom.); Pentair Legend; Polaris PB4-60; Equipment 40' from pool. p.s.: it's an aye-aye.
    Jun 2012
    Louisville, KY
    50
    No wiring or load changes. i just checked it with a multimeter and its still getting 240v.
    I'm going to check the centrifugal switch as mentioned above and report back.
    Thanks guys!
    Jun 2012
    Louisville, KY
    50
    Centrifugal switch was the culprit. The springs were stuck. I threw a little wd40 on them, and its running now.
    Thanks, guys!
    38,272
    Wow, I was just gonna ask about the same problem. I have a 1 year old jandy flo pro 1.5 hp 2speed pump that won't start when the timer kicks on. I did add an autopilot nano to the circuit this year, but everything was fine up until a couple weeks ago. The pump starts fine in low speed, and I can switch to high once it's started.
    Unfortunately I cannot run on low speed as it doesn't generate enough flow for the swcg. I'm going to check the centrifugal switch in the morning.
    ...sure do love this forum..
    -11,000 gallon IG gunite, raised spa overflowing to pool
    -Cleaning Pump: Sta-Rite P6E6E-206L
    (runs what I think is a Vantage system; alternating, rotating floor jets)
    -Filter Pump: Jandy FloPro FHPM1.5-2
    -System 3 S8M150 filter
