Thread: Quick Question, Pool cleaner on craigslist
    Hi everyone,
    I seem to get a lot of dirt in my pool, havent tested to today but thanks to TFP my levels should be perfect and the water is sparkling. I think my system may have some air leaks around the filter as its not sucking as hard but I dont have time to figure that all out today. Also I'm not sure if Im not sure if I have my eyeballs pointed correctly, I was told to point them in a downward angle to kick the dirt on the bottom up but not really working.
    Anyways my question is it would be very helpful to get a vacuum or something to clean the pool with so I dont have to vacuum to waste and screw up my water levels. I saw this Water tech pool blaster on craigslist. They seem to be $130 on Amazon so I think ill try to talk the guy down but can anyone recommend this or should I wait for something else? The other day someone had a polaris automatic robot/pool pump/sand filter/heater on craigslist for FREE! I called within 20 minutes but no one answered or called back
    http://stlouis.craigslist.org/for/3858501092.html
    http://www.amazon.com/Water-Tech-Pool-B ... laster+max
    Aaron
    26' Octagon, IG Pool, ~16gal, 5-5 1/2' deep, Liner, Sand Filter, Polaris Autoclear salt system, 3/4hp Pump, Pool Blaster Max Vacuum, TF-100 Test Kit.
    Re: Quick Question, Pool cleaner on craigslist
    There is also this Polaris 480 for $150
    http://stlouis.craigslist.org/for/3883581890.html
    I don't know much about cleaners so please let me know if either of these are decent and if I should try to get them.
    Aaron
    Mod Squad woodyp's Avatar
    Apr 2010
    East Texas
    9,600
    UnderWaterVanya's Avatar
    Jun 2012
    Mint Hill, NC
    2,589
    The polaris 480 appears to be like their 380, which is a pressure side cleaner these require a dedicated pressure line and a dedicated booster pump in order to work. If you don't have these installed already this could be complicated depending on your setup.
    Sent via Tapatalk...
    I bought the blaster max for $85, guy had used it 3 months, looks brand new. thanks
    Aaron
